Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 06-14-2007, 04:36 PM
ckcn10 is starting off with a positive reputation.
what size tb do you recommend using on the HO intake?
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 06-14-2007, 09:16 PM
jade79 is starting off with a positive reputation.
I agree with Conanski. The AFR (165) / Cobra combo would be the largest head / intake port size I would run in a 5.0 truck that's driven daily. The stock mustang throttlebody would work well, but I would'nt go any larger than a 65mm with either setup. I'm doing a similar build for my 79;
90 mustang 5.0 HO intake, ported lower by Tom Moss. www.tmossporting.com Stock upper with the exception of increasing the throttle body opening to match a Ford Racing 65mm throttlebody.
Ported E7 heads, stock size valves. www.thumperoforangepark.com
Stock 90 mustang HO cam.
Ford Racing 1 5/8 shorty headers with single 3" exhaust and 70 series Flowmaster.
Everything else will be 90 mustang, computer etc.
  #18 (permalink)
Old 06-14-2007, 09:21 PM
wouldn't an HO intake ported with a 65mm throttle body essentially be a cobra intake?
  #19 (permalink)
Old 06-14-2007, 09:50 PM
No, a ported stock still does'nt flow as well as the Cobra, due to the Cobra's larger runner size. Porting the stock lower makes the flow more equal between runners. Some runners had sharp bends and did'nt flow as well as others. This way, breathing is improved without sacrificing any low rpm power.
  #20 (permalink)
Old 06-14-2007, 09:53 PM
Did all HO intakes have flow variations between ports? Or does it just depend on each intake individually?
  #21 (permalink)
Old 06-14-2007, 10:05 PM
It seems most of the stock mustang 5.0's did. The Cobra's, Explorers, and GT40s were more equal. Must be something to do with the staggered runner design.
  #22 (permalink)
Old 06-14-2007, 10:39 PM
how are the trucks? probably have huge variations huh?
  #23 (permalink)
Old 06-14-2007, 11:03 PM
Conanski's Avatar
Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.Conanski has a good reputation on FTE.
Quote:
All intakes will show some variation between runners. In general, EFI intakes are much better than carb'd intakes at balancing air flow on each cylinder, but some are better than others. The car intakes are compromised due to space restrictions in the engine bay, but the trucks have no such problem so I doubt they would show as much variation. The limitations of the factory car intakes are well documented, but not so much for the truck intakes. Oh to have a flow bench and engine dyno...
__________________
Paul O
1990 F150 4x4 XLT X-Cab 5.0, 3.55, Comp 35-349-8, Flowtech LT's to 3" single, FRPP Mass Air Conversion
Under construction: '85 351HO, Dart Iron Eagles, Roller Rockers, Typhoon intake, Crane 444232, 24lb Injectors, TweecerRT, Innovate LC-1 wideband O2
1990 Ranger 2wd, 2.3 Briggs & Stratten, 5-speed, 3.08 gears, sliding rear window.
  #24 (permalink)
Old 06-15-2007, 03:08 AM
yea no kidding
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
