blast media vs nozzle size - Ford Truck Enthusiasts Forums
Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Old 06-09-2007, 09:26 PM
ferret2 ferret2 is offline
ferret2 is starting off with a positive reputation.
Is there a rule of thumb for matching sandblast media vs blast nozzle diameter? I have both 3/32 and 1/8" diameter nozzles.
Thanks
Old 06-10-2007, 09:54 AM
daveengelson daveengelson is offline
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Not an authority, believe compressor output, CFM, will dictate size nozzle and thus determine media size. I am limited to nozzle size because have a small shop compressor rated approx. 6.5 CFM @ 90psi. When I purchased the sandblaster also purchased some of seller's blasting media later found was too large, nozzle kept clogging up. Once I went to smaller media equipment worked great.
dave
Old 06-10-2007, 12:40 PM
cujo8's Avatar
cujo8 cujo8 is offline
cujo8 is starting off with a positive reputation.
Quote:
dave
Dave is correct in that the compressor CFM will dictate which nozzle size to use, which in turn determines the size of the media. If you use too big of a nozzle on a small compressor the compressor will run all the time and still won't be able to keep up with the blast cabinet. This will eventually kill your compressor, since they are not intended for 100% duty cycle.
Q. What size nozzle and how much air do I need?
A. The nozzle and air jet size determines the air requirements. The air jet fits inside the power gun and controls the amount of air leading to the nozzle. Nozzles and air jets can be changed, depending on your air compressor. If you have a 3 HP compressor (7 cfm), your best choice is probably the small nozzle. If you have a 5 HP compressor (15-20 cfm), use a medium nozzle. For a 10 HP or larger compressor, use a large size nozzle. Remember, nozzles and air jets must be changed in sets (small with small, etc.) and are available in steel, ceramic and carbide.
Characteristics of Abrasives: Most abrasives are graded as to Sieve Size. A sieve is a utensil of wire mesh or closely perforated metal used for straining or sifting, and can be used to separate coarser abrasive from finer abrasive. As the abrasive is poured through the sieve, the larger particles remain. The sieve is rated by the number of openings per square inch, so the higher the number, the finer the mesh. Also, the higher the number, the finer the abrasive. If an abrasive is graded 60-80, it means that it will pass through a grade 60 mesh sieve. Coarser abrasives (lower numbers) normally cut faster and create less dust within the cabinet, however the finish can be so coarse that the surface being blasted is extremely rough. If intending to paint or do further preparation on the metal, it is better to use a finer abrasive, to save prep time later. In summary: higher mesh numbers mean finer finishes and slower cutting action. Lower numbers mean coarse finishes and faster cutting action. Experiment with various types and grades of abrasive until you select your "favorites".
In summary, for satisfactory operation when cabinet blasting or using any air tool requiring large amounts of air, please observe the following recommendations:
1. Change nozzles frequently -- consider going to a smaller size to save air, or using a long-wearing Carbide Nozzle which will maintain its orifice size for a longer period of time.
2. Do not blast continually. Take a break every 5 minutes to allow air compressor to cool.
3. If air compressor tank feels hot (warm is normal), and is running continually, stop operating the cabinet or air tool and allow compressor to cool. Otherwise, compressor will overheat and eventually break down. Compressors are not guaranteed against this condition.
4. Compressor must recycle normally on and off and run no more than 2/3 the time. No air compressor is designed for continual operation. Know the capacity of your compressor and the amount of air required for your air tools, and allow a 50% overload factor for best results. (Example: Tool requires 10 CFM air. You need 15 CFM as an overload factor.)
5. Use a minimum 3/8" ID air hose up to 25 ft, from air compressor to cabinet and remember to consider air pressure drop as illustrated in table below. Example: If using 25 feet of 1/4" ID air hose, at 60 lbs pressure, you will experience a pressure drop of 19 lbs, meaning you actually have 41 lbs working pressure.
<table id="Table2" border="1" cellpadding="3" cellspacing="0" height="189" width="583"> <tbody><tr> <td colspan="8"> Air Pressure Drop with 1/4" or 5/16" ID Air Hose
</td> </tr> <tr> <td colspan="2">. </td> <td colspan="2">
Pressure Drop (Loss)
</td> <td colspan="2">. </td> <td colspan="2">
1/4" ID Air Hose
</td> <td height="23" width="12%">
25 feet
</td> <td width="12%">
50 feet
5/16" ID Air Hose
</td> <td width="13%">
25 feet
50 feet
</td> </tr> <tr> <td colspan="2">At 60 lbs pressure</td> <td height="23" width="12%">
19 lbs
31 lbs
</td> <td colspan="2">At 60 lbs pressure</td> <td width="13%">
6 lbs
11 lbs
</td> </tr> <tr> <td colspan="2">At 70 lbs pressure</td> <td height="23" width="12%">
22 lbs
34 lbs
</td> <td colspan="2">At 70 lbs pressure</td> <td width="13%">
7 lbs
13 lbs
</td> </tr> <tr> <td colspan="2">At 80 lbs pressure</td> <td height="23" width="12%">
25 lbs
37 lbs
</td> <td colspan="2">At 80 lbs pressure</td> <td width="13%">
8 lbs
14 lbs
</td> </tr> <tr> <td colspan="2">At 90 lbs pressure</td> <td height="23" width="12%">
29 lbs
39 lbs
</td> <td colspan="2">At 90 lbs pressure</td> <td width="13%">
10 lbs
16 lbs
</td> </tr> <tr> <td colspan="2">At 100 lbs pressure</td> <td height="23" width="12%">
33 lbs
42 lbs
</td> <td colspan="2">At 100 lbs pressure</td> <td width="13%">
12 lbs
18 lbs
</td> </tr> </tbody></table> Metal piping is always preferred to air hose, as it allows the moisture-laden air to condense in the piping, where it can be removed later with the water separators.
Old 06-10-2007, 05:05 PM
Everyone thanks for your concern about cfm but believe me air volume is not the issue. I will ask again - what mesh size media is recommended for a 3/32 and 1/8 inch nozzle.
Old 06-10-2007, 09:38 PM
cujo8's Avatar
70 - 100 Mesh size is what I use in my blast cabinet. I usually use aluminum oxide with an 80 grit mesh size and occasionally I use glass bead with a 70-100 mesh size. I have used both with small and medium nozzle sizes and I have never had any trouble with nozzle plugging. Hope this helps.
injector nozzle size - e-fuel postfilter size? OldWoodsDiesel 1994.5 - 1997 7.3L Power Stroke Diesel 16 11-15-2014 06:15 PM
Sand blaster not quite workin' rhw Paint & Bodywork 10 03-21-2012 07:35 PM
Media Blasting Fordication Southwest Region 0 05-30-2008 11:09 PM
Fuel Filler Adapter? nlemerise 1999 - 2003 7.3L Power Stroke Diesel 5 05-07-2006 01:22 PM
sand blast cabinet nozzle size and type dynamic Garage & Workshop 9 11-03-2004 04:23 PM
Tags
332, 4, 80, beads, blast, blasting, correct, glass, grit, inch, media, mesh, nozzle, nozzles, recommended, size
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
