I have a v6 3L in one of my Fords. I notice the temp gauge starting to get higher than normal (warmer) while I wait at a fast food window or just setting at an idle. Soon as I'm able to move it drops back donw into the mid range normal. 2 years ago I replaced the raditor, and had it power flushed and they replaced the thermostat and a few years ago I replaced the heater core.. what maks it get warn when not moving and cools off so instantly when moving? This a 99 motor...could it be the thermostate so soon? Suggestions?
__________________ 93 F350 XLT 4x4 Crew Cab 7.3L Turbo
69 F250 390 Ranger Camper Special
89 Full size Bronco
02 and 07 Focus, 99 Taurus
02 Ranger
E150 Custom Van
Nam 69/70 25th Inf Div
http://home.comcast.net/~lonallie/
http://home.comcast.net/~ATrp3-4Cav/
well never thought about the fan clutch (about the only thing I haven't replaced so far), any way of testing that? Also when I had the heater core replaced a shop did the core and Ford did the radiator. Never heard of using distilled water before. What does that do?
89 Full size Bronco
02 Ranger
E150 Custom Van
Regular tap water contains dissolved minerals that can contribute to deposit formation and restricted flow in the radiator.
Distilled water is, well, just pure water.
Keep in mind, other "bottled waters" are not necessarily pure water.
You might even see something like "with dissolved minerals for improved taste".
Pure water has no taste; it is just hydrogen and oxygen.
Also, proper coolant change intervals is recommended to keep the corrosion inhibiting properties.
Oh, question, anyone know how to check the electric fan? With-out having to stand and let it heat-up? Does it have a fuse? Can you pull wires to see if they have juice? Thoughts?
89 Full size Bronco
02 Ranger
E150 Custom Van
