Stock Cam Specs? - Ford Truck Enthusiasts Forums
Stock Cam Specs?
Old 06-09-2007, 04:03 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
Stock Cam Specs?
I am looking for info to compair these cam to the stocks Part Number:379601
<table align="center" border="1" cellpadding="6" cellspacing="0" width="550"><tbody><tr><td colspan="2"><table border="0" cellpadding="2" cellspacing="0" width="100%"><tbody><tr><td class="formTitlesLeft" width="20%">Valve Setting:</td><td class="formSubtitlesRight" width="14%">Intake</td><td class="formEntries" width="14%">.000</td><td class="formSubtitlesRight" width="11%">Exhaust</td><td class="formEntries" width="15%">.000</td><td class="formEntries" width="26%">HOT</td></tr></tbody></table></td></tr><tr><td colspan="2"><table border="0" cellpadding="2" cellspacing="0" width="100%"><tbody><tr><td class="formTitlesLeft" width="6%">Lift:</td><td class="formSubtitlesRight" width="29%">Intake @Cam</td><td class="formEntries" width="7%">300</td><td class="formSubtitlesRight" width="10%">@Valve</td><td class="formEntries" width="7%">550</td><td rowspan="3" class="formtext" valign="top" width="28%">All Lifts are based
on zero lash and theoretical rocker arm ratios.</td></tr><tr><td rowspan="2" class="formSubtitles"> </td><td class="formSubtitlesRight">Exhaust @ Cam</td><td class="formEntries" width="7%">300</td><td class="formSubtitlesRight">@Valve</td><td class="formEntries" width="7%">550</td></tr><tr><td class="formSubtitlesRight">Rocker Arm Ratio</td><td class="formEntries" width="7%">1.80</td><td class="formSubtitlesCenter"> </td><td class="formSubtitlesCenter"> </td></tr></tbody></table></td></tr><tr><td colspan="2"><table border="0" cellpadding="2" cellspacing="0" width="100%"><tbody><tr><td class="formTitles" width="16%">Cam Timing:</td><td class="formEntries" width="11%">VALVE</td><td colspan="3" class="formEntries">@.006</td></tr><tr><td class="formTitles">Lift:</td><td class="formTitles"> </td><td class="formSubtitles">Opens</td><td class="formSubtitles">Closes</td><td class="formSubtitles">ADV Duration</td></tr><tr><td class="formSubtitlesRight" width="16%"> </td><td class="formSubtitlesRight" width="11%">Intake</td><td class="formEntries" width="16%">14.0 BTDC</td><td class="formEntries" width="17%">54.0 ABDC</td><td class="formEntries" width="40%">248.0 </td></tr><tr><td class="formSubtitlesRight"> </td><td class="formSubtitlesRight">Exhaust</td><td class="formEntries">67.0 BBDC</td><td class="formEntries">7.0 ATDC</td><td class="formEntries">254.0 </td></tr></tbody></table></td></tr><tr><td width="73%"><table border="0" cellpadding="2" cellspacing="0" width="100%"><tbody><tr><td colspan="7" class="formTitlesLeft">Spring Requirements: Triple Dual Outer Inner</td></tr><tr><td class="formSubtitles" width="21%">Part Number</td><td colspan="6" class="formEntries">37830</td></tr><tr><td class="formSubtitles">Loads</td><td class="formSubtitlesRight" width="10%">Closed</td><td class="formEntries" width="7%">85</td><td class="formSubtitlesRight" width="9%">LBS @</td><td class="formEntries" width="9%">1.640</td><td class="formSubtitlesCenter" width="6%">or</td><td class="formEntries" width="38%">1 41/64</td></tr><tr><td class="formSubtitlesRight"> </td><td class="formSubtitlesRight">Open</td><td class="formEntries">195</td><td class="formSubtitlesRight">LBS @</td><td class="formEntries">1.110</td><td> </td><td> </td></tr></tbody></table></td><td width="27%"><table border="0" cellpadding="2" cellspacing="0" width="100%"><tbody><tr><td colspan="2" class="formtext">Recommended RPM range with matching components</td></tr><tr><td class="formSubtitles" width="78%">Minimum RPM</td><td class="formEntries" width="22%">1600</td></tr><tr><td class="formSubtitles" height="24">Maximum RPM</td><td class="formEntries">5500</td></tr><tr><td class="formSubtitles">Valve Float</td><td class="formEntries">6100</td></tr></tbody></table></td></tr><tr><td colspan="2"><table border="0" cellpadding="2" cellspacing="0" width="100%"><tbody><tr><td class="formTitles" width="16%">Cam Timing:</td><td class="formEntries" width="10%">VALVE</td><td colspan="4" class="formEntries">@.050</td></tr><tr><td class="formTitles">Lift:</td><td class="formTitles"> </td><td class="formSubtitles">Opens</td><td class="formSubtitles">Closes</td><td class="formSubtitles">Max Lift</td><td class="formSubtitles">Duration</td></tr><tr><td class="formSubtitlesRight" width="16%"> </td><td class="formSubtitlesRight" width="10%">Intake</td><td class="formEntries" width="15%">(4.0) ATDC</td><td class="formEntries" width="17%">36.0 ABDC</td><td class="formEntries" width="13%">110</td><td class="formEntries" width="29%">212.0 </td></tr><tr><td class="formSubtitlesRight"> </td><td class="formSubtitlesRight">Exhaust</td><td class="formEntries">49.0 BBDC</td><td class="formEntries">(11.0) BTDC</td><td class="formEntries">120</td><td class="formEntries">218.0
</td></tr></tbody></table></td></tr></tbody></table>
Old 06-10-2007, 11:06 PM
Johnny Langton's Avatar
Johnny Langton Johnny Langton is offline
Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.Johnny Langton has a great reputation on FTE.
Awhile back I personally checked 10 sets of cams-both NPI and PI from both cars and trucks just to verify the OEM specs. Duration and centerlines are the same,lift is the only difference.
Non-PI:
Intake .462" lift/201 @.050"
Exhaust .462" lift/208 @.050"
114 intake C/L
113 exhaust C/L
PI:
Intake .507" lift/200 @.050"
Exhaust .534" lift/210 @.050"
114 intake C/L
115 exhaust C/L
The duration and centerlines are so close that I'll say the slight differences seen are production tolerances.
JL
Old 11-30-2008, 11:32 AM
Skoda's Avatar
Skoda Skoda is offline
Skoda is starting off with a positive reputation.
very interesting info guys, no wonder the pi version heads have more power gains to them. I'am not stating the cams are the only reason but they sure do help
I probalby know the answer to this qeustion but have to be certain, are these cam specs the same for the V10?
Old 11-30-2008, 11:46 AM
If you have a little time to kill-here's a good read on that PI-NPI subject and how the PI makes more power:
PI vs NPI-data - Modular Depot Forums
It took me along time to put all of that data together and do the comparisons. it's a bit of a long read,but worth it.
Everything I've seen indicates that the 6.8L uses the exact same cam lobes as the 5.4L and the 4.6L. Ford mass produces the lobes and the camshaft tubes and press-fits them for assembly and final griding to spec. They're not gonna waste time setting up their machinery to grind different lobe profiles when they control engine power/torque with the intake manifold design.
JL
Old 11-30-2008, 02:35 PM
Skoda's Avatar
Thanks for the link johnny
yes it is rather amazing how exhuast and intake sizing and flow along with tunned ramming have an effect on an engines power curve let alone feel to the driver, Though I know can get non pi heads to make more power then pi heads
when you posted the flow numbers do those cylinder heads still have the stock valve angles?
aswell were the pi heads ported along with the non pi heads? what I mean is are the flow numbers the results after both heads have been ported?
say you wouldn't happen to know what the 3v cam lift is would yea?
Old 11-30-2008, 05:10 PM
Yes,the flow numbers for both were ported,and my Non-PI head have the stock angles,etc. They've had new valves installed,good valvejob and port blending work,etc,etc,but they're not some special one-off racecar only piece.
Don't have any data on the 3V cams.
JL
Old 12-10-2012, 02:10 AM
Nathan28's Avatar
Nathan28 Nathan28 is offline
Nathan28 is starting off with a positive reputation.
1986/302 f150
4x4 ford f150
Old 12-10-2012, 04:51 PM
blackout150's Avatar
blackout150 blackout150 is offline
blackout150 is starting off with a positive reputation.
Quote:
Originally Posted by Nathan28 View Post
I got a jacked up 4x4 ford f150 with a stock 302 in it. i want to get more horsepower out of the motor so I've purchased a performance camshaft for it now i'm worried that it wont work with out changing the original valve springs. I don't want to have to bore if i don't have to. I put a Edelbrock four barrel 600 cfm carburetor on it to help it breathe better. The specs on the cam shaft i bought is: intake and exhaust duration is 244/244, intake and exhaust valve lift is 534/534, rpm range 2000 to 9000. I'm trying to get the horsepower out of the cam while still being able to use the original valve springs, Etc.! If any one knows what i may be talking about your response would be greatly appreciated!!!
First, your in the wrong forum for that info. Second, why in the heck would you pick a 2000-9000 rpm range cam for a jacked up 4x4? Your going to have no low end which is what you need. No way stock valve springs on a 302 are good for 9000 rpm's either.
Old 12-11-2012, 12:39 PM
Nathan28's Avatar
Ha Ha Ha
Man.... i been trying to find the place where i typed on the computer for about 6 or 7 hours!!!! forum huh, whats that? whats a thread???? I know what reply means.... How do i do an introduction thread; or is it called a post??? How am i supposed to post a post if there is no post button.... All this is so confusing.
Im eager to start but don't know how!!!! Thanks for sending that reply to my email because i would never have found it!!!!
Old 12-11-2012, 12:56 PM
Nathan28's Avatar
Blackout150
Hey man im going to find the right forum once i get this site figured out, my bad bro........ ima try not to muck up your page man. take care!!!
09 F150 Major Electrical Issue EALightingSolutions 2009 - 2014 F150 2 05-17-2015 10:45 PM
test BOSSY 1973 - 1979 F-100 & Larger F-Series Trucks 0 12-26-2014 10:07 PM
Service Bulletin for 2009-2010 EGR Valve repairs senix 6.4L Power Stroke Diesel 0 01-31-2011 02:46 PM
I have a timing problem!! Questions.... fishindave11 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 8 11-16-2008 03:27 PM
my oasis report indebt 1999 - 2003 7.3L Power Stroke Diesel 7 11-07-2008 10:29 PM
Tags
200, 46, 46l, 54, 97, cam, camshaft, camshafts, engine, events, ford, lift, max, specs, stock, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
