You can leave the entire drivetrain in place when you pull the tub. Just have to disconnect everything between the frame and the body. And also remove things like the transfer case shift that protrude through the body
Remove the doors, fenders, grille, hood, tailgate, and anything else that is attached to the body. You need to build some supports to go between the front and rear door posts as the tub will try to collapse when you lift it.
Jason
__________________
'93 F350 CC 4wd 7.3L 5spd, 240K miles
'69 Bronco SEFI 5.0, NP435, geared, locked...
'77 F150 4wd 351M, 435, 205
'79 F150 4wd lwb 400, 435, 205
"You can take the boy out of the trailer park, but you can't take the trailer park out of the boy."
