E4OD transmission, 95 F-250 - Ford Truck Enthusiasts Forums
Computer Chips & Tuners SPONSORED BY:
Old 08-18-2002, 02:41 PM
RepoMan801 RepoMan801 is offline
RepoMan801 is starting off with a positive reputation.
Post E4OD transmission, 95 F-250
I recently bought a used 1995 F-250 with a 5.8 and an E4OD tranny. (Automatic) When driving in OD, the unit suddenly shifts erratically, then seems like it goes into neutral. If I slow down and/ or stop, it goes back into the lower gears, where it drives fine. After a min. or so, it acts erratically in 2nd and 3rd gear too. I had the transmission rebuilt at an aamco, the replaced several mechanical items, including a selinoid (sp?), shift control comp. module, etc. at a cost of almost $1900. Well, on the way home, after I drove it about 20 miles, it started doing the exact same thing again! Does anyone have any idea what could be wrong with it? I am taking it back to aamco (warranty) but if they knew what it was, it seems like they would have fixed it the first time..
If anyone can help, of if I need to provide anymore info. for help info, please let me know! Thank you.
Elton.
Old 08-18-2002, 06:16 PM
FTE Ken's Avatar
FTE Ken FTE Ken is offline
FTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputationFTE Ken has a superb reputation
Try this question in the transmission section.
Old 08-18-2002, 08:46 PM
FTE Ken's Avatar
transmission frustration Skape 1994.5 - 1997 7.3L Power Stroke Diesel 8 07-25-2012 08:48 PM
1994 f350 Intermittant blinking OD light, wont shift into OD 1wvboy 1987 - 1996 F150 & Larger F-Series Trucks 2 03-04-2012 03:10 PM
just rebuilt 95 351 shifting rough need help richdavis69 1987 - 1996 F150 & Larger F-Series Trucks 17 05-23-2011 08:49 AM
aamco E4od problems jepps Clutch, Transmission, Differential, Axle & Transfer Case 16 12-27-2006 12:25 AM
1995 F-250 E4OD transmission problems,..... RepoMan801 Clutch, Transmission, Differential, Axle & Transfer Case 12 09-01-2002 12:02 PM
Tags
95, e4od, erradiclly, f250, fte, shifts, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
