2000 F350 remote entry issues
The key fob for my 2000 F350 doesn't work worth a $h!#. I have two fobs and both work poorly. 99% of the time, I have to hold the fob next to the window of the truck and it may work occasionally. Sometimes I can be 20 feet away and it works! I have changed the battery in both fobs and no difference.
Does anyone know if there is an antenna or some way to improve this?
Thanks,
Dave
Thanks,
Dave
Have you tried re-programming to see what happens?
Remote Transmitter Programming
NOTE: All keyless entry remote transmitters (15K601) must be programmed at the same time.
NOTE: To program (or reprogram) the keyless entry remote transmitters into the generic electronic module (GEM), perform the following steps.
Excursion
Turn the ignition from OFF to RUN eight times within 10 seconds, ending in RUN. If the GEM has successfully entered the program mode, it will lock and unlock all the doors.
F-Superduty 250-550
Turn the ignition from OFF to RUN five times within 10 seconds, ending in RUN. If the GEM has successfully entered the program mode, it will lock and unlock all the doors.
All vehicles
Press any button on a keyless entry remote transmitter, and the doors will lock and then unlock to confirm that each keyless entry remote transmitter has been programmed.
If the door locks do not respond for any keyless entry remote transmitter, wait for several seconds and press the button again.
Turn the ignition switch to the OFF position, or wait up to five minutes after Step 1, to exit program mode. If a keyless entry remote transmitter has been programmed (or reprogrammed), the GEM will lock and unlock all the doors one last time.
Excursion
F-Superduty 250-550
All vehicles
