Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-07-2007, 08:35 PM
rsalter66's Avatar
rsalter66 rsalter66 is offline
Garage is empty, add now
rsalter66 is starting off with a positive reputation.
can anyone tell me bout dual fuel set-ups
i've been hearing bout dual fuel? propane + gasoline? how do you do it? can ya switch back n forth? can you use the pane as a power adder? with nitrous" + supercharger? so many question's i have! can anyone point me in the direction of a site for answer's? thank's
  #2 (permalink)
Old 06-07-2007, 10:51 PM
christcorp's Avatar
christcorp christcorp is offline
christcorp is gaining momentum as a positive member of FTE.
I have no idea on the hows of it. I can only say that it definitely exists and does apparently work fine. I retired from the Air Force in 1999, and about 6 months before I left, I got a new van for our maintenance shop. It had a regular gasoline fuel tank as well as a propane tank behind the 2 front seats. (It was a full van and only had front seats). The propane tank was pretty good size. (That showed that it would only really be feasible in a van or pickup truck). Our van was set up to automatically switch over from gas to the propane tank when the gas level got to about 1/4 of a tank. OR, you could manually switch it back and forth with a switch, just like with dual gas tanks.
It ran perfectly fine for us. Couldn't tell any difference in performance between the two. Obviously it only had the one fuel delivery system, so somehow is was configured to run both gasoline and propane without a problem. I don't know the hows of it. We had one official propane (Gas Station) in town to fill it up at, but supposedly the connection was compatible to be filled up at a normal location that sold propane.
Anyway, it worked fine. But because of the displacement of propane compared to gasoline, it required a pretty good size tank for the vehicle. It was about 4ft long, 2ft high, and 2ft wide. Not something you would put into a car. Later... Mike....
__________________
The Ford Family:
2000 Ford Focus - 143,000 miles
1994 Ford Explorer (4.0l V6) - 114.000 miles
1994 Ford F250 (460 V8) - 65,100 miles
1966 Ford Mustang (289 V8) - 141,200 miles
"Born Wild; Raised Proud"
Tags
dual, propane, tank, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
