98 Ford Ranger Clutch
Old 06-07-2007, 04:51 PM
Russ8393's Avatar
Russ8393
Russ8393 is offline
I have a 98 Ford Ranger with a 3.0 liter engine that was replaced in December 06. I have a 5 speed transmission and the clutch and slave cylinder was replaced when the engine was replaced. A few weeks ago I noticed that some of the time it was very hard to get it to go into gear. So I deceided to bleed the clutch. This made it improve but just a few days later it started to get hard to put it in gear. So I bled the clutch agian and once again it got better but now it is hard to get into gear. I have had this problem off and on for several years and have had the slave cylinder replaced a few times. I think that the problem has to be in the system between the reservoir and the QD for the slave cylinder. Please let me know what you think.
Old 06-07-2007, 05:21 PM
ranger88a's Avatar
ranger88a
ranger88a is offline
Your slave cylinder may be leaking. Is the fluid leaking down in the resevoir?
Old 06-07-2007, 05:22 PM
Russ8393's Avatar
Russ8393
Russ8393 is offline
No Fluid leak
No Fluid leak
Old 06-07-2007, 07:20 PM
moat's Avatar
moat
moat is offline
Have you replaced the master cylinder? It's possible that it's allowing air into the system. A lot easier and cheaper than R&R'ing the slave.
Old 06-07-2007, 07:50 PM
Russ8393's Avatar
Russ8393
Russ8393 is offline
Where is the master cylinder?
Old 06-07-2007, 08:02 PM
moat's Avatar
moat
moat is offline
Master cylinder is what the clutch pedal "pushes" (via a pushrod). Mounted to the firewall, above the driver's left foot. Slave cylinder is down inside the bellhousing, between the transmission and clutch/engine.
Bob
Old 06-07-2007, 08:26 PM
Russ8393's Avatar
Russ8393
Russ8393 is offline
Is the master cylinder hard to change? How long will it take? I'm an experienced machanic although on aircraft.
Old 06-07-2007, 08:36 PM
moat's Avatar
moat
moat is offline
Nope - easy. About an hour, at most. No harder than replacing a brake master cylinder on a Cessna 172, really...! Now, a Beech Baron 58... hmmm...
The key to a successful job, tho, is to bench-bleed the new master, before you install it. Otherwise, they can be a bit tricky to bleed. Take a look at this thread for the full story -
https://www.ford-trucks.com/forums/2...ding-help.html
Bob
Old 06-08-2007, 08:24 PM
98range's Avatar
98range
98range is offline
I changed mine on a 93 ranger. The time is about 1 hour and I bleed the brakes on the truck. Worked fine after new master installed.
Old 07-16-2007, 07:06 PM
surfkovo's Avatar
surfkovo
surfkovo is offline
I bought my '98 used with 48k on it. Had the same problem. Changed the master cylinder, and it cleared the problem. It's still never been the smoothes shifting truck, but before I replaced it I had a miserable time.
Old 07-16-2007, 07:10 PM
RangerPilot's Avatar
RangerPilot
RangerPilot is offline
Check on the inside and outside of the firewall around the master cylinder, a little fluid may be present on either side if it's the problem.
Old 07-17-2007, 11:12 AM
thanksbutnothanks's Avatar
thanksbutnothanks
thanksbutnothanks is offline
If your truck is hard to get into gear try changing the transmission oil. I know, it sounds crazy. This is a manual tranny after all. I changed my slave cylinder and shortly thereafter it became hard to get into gear, especially fourth. It came time to change the tranny oil so I had it done and Voila! The hard shift was gone. It's smooth as a silk now.
templars
09-14-2019 07:42 PM
Broncoslocos
04-08-2015 12:20 PM
BLADE35
23
06-29-2014 12:29 PM
thanksbutnothanks
01-03-2007 03:54 AM
glenn65
16
12-31-2005 12:16 AM
Quick Reply: 98 Ford Ranger Clutch
