Plug wire routing
Old 06-07-2007, 11:12 AM
92F150Flare's Avatar
92F150Flare
92F150Flare is offline
Plug wire routing
I put those 9mm Ford Racing wires on and I'm wondering if anyone can tell me a good way to route the passenger bank.......No's 1,2,3,4. I've never seen the factory routing so I'm totally unfamiliar with that.
I do want to get some looms and/or separators and clean it up. Ideas on the Drivers side bank are great too.
Thanks
Bob
Old 06-07-2007, 02:48 PM
bobcf's Avatar
bobcf
bobcf is offline
Old 06-07-2007, 08:39 PM
brown 4x4's Avatar
brown 4x4
brown 4x4 is offline
That pic is for the late 302 firing order, but I guess it can give you some idea. Your 92's firing order is 15426378.
Here's my passenger side. Drivers side is in my gallery also.
BTW, nice choice of wires.
Old 06-08-2007, 05:05 PM
bobcf's Avatar
bobcf
bobcf is offline
heres a better one
1,5, routing
Old 06-08-2007, 05:37 PM
bobcf's Avatar
bobcf
bobcf is offline
Old 06-10-2007, 12:24 PM
Old_Paint's Avatar
Old_Paint
Old_Paint is offline
WHATEVER you do, make sure that you don't run 7 & 8 side by side. I speak from experience, the engine will run like poop if you don't keep those two separated as long as possible. EVEN with new wires, you will get crossfire on 7 and 8.
The following users liked this post:
Old 08-07-2007, 09:26 AM
Mr. M's Avatar
Mr. M
Mr. M is offline
Originally Posted by bobcf
Excellent link Bob. Thanks.
Old 10-02-2007, 11:18 AM
andrewsmith's Avatar
andrewsmith
andrewsmith is offline
Would this be the same for newer 5.0s?
Old 10-02-2007, 05:32 PM
EPNCSU2006's Avatar
EPNCSU2006
EPNCSU2006 is offline
Scroll up, there's a link for both 5.0L firing orders...
Old 10-04-2007, 03:46 PM
bobcf's Avatar
bobcf
bobcf is offline
Your welcome... glade to help
Old 01-12-2008, 01:47 PM
second chance's Avatar
second chance
second chance is offline
Moroso makes a wire loom kit for 5.0 Ford, that's what I used when I put the 8.8 300+ Accels on my 95.Got mine at a local speed shot for 9.95.
Old 02-23-2008, 05:02 PM
alien4fish's Avatar
alien4fish
alien4fish is offline
i need the firing order for a 4.9 300cid, any one have the layout?
Old 02-23-2008, 05:30 PM
quicklook2's Avatar
quicklook2
quicklook2 is offline
answered already in your other post.
Old 03-09-2009, 07:44 PM
95gearhead's Avatar
95gearhead
95gearhead is offline
Post 5.8lightning engine swap into5.0 place
I am looking to find a 5.8 lightning engine to put in my 95 F150 project truck. Anyone got any info? will the transmisssion bolt up? both trucks are 2wd, but my truck is supercab.tranny is aode.
Old 03-24-2009, 11:09 PM
Mr. M's Avatar
Mr. M
Mr. M is offline
You can buy a lightning shortblock from svo for about $1700. However, I would hesitate for you to mate that behind an aod-e. Unless you are fluent in the binary code utilizing TweeCer or Moates QH. There may be a mustang binary code that you could tweak to make it work... but it will be on your shoulders to beta test it.
If you are set on a the lightning block setup...you would be best off finding a rebuildable e4od tranny core ($250-400) (make sure it is a small block bellhousing as well) and swap the lightning block at the same time. A lightning ECU is a cheap find if your savvy in junk yards or ebay. The lightning SD ecu will tame the motor and tranny in tandem. If it wasn't an electronically controlled AOD... you would have many many more options.
The only tricky part of this swap will be finding a driveshaft of correct length. This is secondary to having the motor and tranny behaving together, and properly, in my opinion. Worst case scenario... a custom length driveshaft might leave you $300 more in parts.
A mismatched tranny, motor, ecu logic, you name it... can you leave you much deeper in the pockets.
My $.02
Good luck sir.
Quick Reply: Plug wire routing
