Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1987 - 1996 F150 And Larger F-Series Trucks
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
1987 - 1996 F150 And Larger F-Series Trucks SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-07-2007, 12:12 PM
92F150Flare 92F150Flare is offline
92F150Flare is gaining momentum as a positive member of FTE.
Plug wire routing
I put those 9mm Ford Racing wires on and I'm wondering if anyone can tell me a good way to route the passenger bank.......No's 1,2,3,4. I've never seen the factory routing so I'm totally unfamiliar with that.
I do want to get some looms and/or separators and clean it up. Ideas on the Drivers side bank are great too.
Thanks
Bob
__________________
`92 F150 Flareside - IRIS MET/Gray
5.0, AOD, 355 gears, dual glasspacks no cats, K&N drop in filter, MSD Blaster Coil, Cap and Rotor, Ford Racing 9mm wires - Blue
It's not pink......it's IRIS.
Have a look at my truck
Come visit the South Carolina chapter here!
  #2 (permalink)
Old 06-07-2007, 03:48 PM
bobcf's Avatar
bobcf bobcf is offline
bobcf is starting off with a positive reputation.
wire routing
__________________
Bob
94 aerostar 4.0
92 c150 351w
88 f250 460
  #3 (permalink)
Old 06-07-2007, 09:39 PM
brown 4x4 brown 4x4 is offline
brown 4x4 is starting off with a positive reputation.
That pic is for the late 302 firing order, but I guess it can give you some idea. Your 92's firing order is 15426378.
Here's my passenger side. Drivers side is in my gallery also.
BTW, nice choice of wires.
__________________
1997 F-250 Supercab 4x4 7.3 PSD ZF 4.10 169K pics
1995 F-150 Supercab 4x4 5.0 M5OD 3L55 251K (daily driver) pics
1995 F-150 Supercab 4x4 5.0 (#2) 4R70W (weak but original) 3.31 333K (rusty work truck) pics
94 F-150; (2) 78 F-150 4x4's; 79 F-150 4x4; 79 F-150 302 EFI; 79 Lincoln Continental
  #4 (permalink)
Old 06-08-2007, 06:05 PM
bobcf's Avatar
heres a better one
1,5, routing
__________________
Bob
94 aerostar 4.0
92 c150 351w
88 f250 460
  #5 (permalink)
Old 06-08-2007, 06:37 PM
bobcf's Avatar
1,3, routing
__________________
Bob
94 aerostar 4.0
92 c150 351w
88 f250 460
  #6 (permalink)
Old 06-10-2007, 01:24 PM
Old_Paint Old_Paint is offline
Old_Paint is gaining momentum as a positive member of FTE.
WHATEVER you do, make sure that you don't run 7 & 8 side by side. I speak from experience, the engine will run like poop if you don't keep those two separated as long as possible. EVEN with new wires, you will get crossfire on 7 and 8.
__________________
Old Paint
1992 F-150 SWB,5.0L EFI - EEC-IV, M5OD
1986 T-Bird, 3.8L CFI, C5
1970 VW Beetle Baja, A REAL VW
A Redneck's last words: "HEY, watch this!"
  #7 (permalink)
Old 08-07-2007, 10:26 AM
Mr. M's Avatar
Mr. M Mr. M is offline
Mr. M is starting off with a positive reputation.
Quote:
Originally Posted by bobcf
Excellent link Bob. Thanks.
__________________
94 F150 XLT
Mild 306 (soon to be powering a 68 ranchero)
E4OD Trans Go shift kit
Parting up for 408w swap
  #8 (permalink)
Old 10-02-2007, 12:18 PM
andrewsmith andrewsmith is offline
andrewsmith is starting off with a positive reputation.
Would this be the same for newer 5.0s?
  #9 (permalink)
Old 10-02-2007, 06:32 PM
EPNCSU2006's Avatar
EPNCSU2006 EPNCSU2006 is offline
EPNCSU2006 has a good reputation on FTE. EPNCSU2006 has a good reputation on FTE. EPNCSU2006 has a good reputation on FTE.
Scroll up, there's a link for both 5.0L firing orders...
__________________
Eric
'87 F150 302 manual 4sp overdrive 4x2
  #10 (permalink)
Old 10-04-2007, 04:46 PM
bobcf's Avatar
Your welcome... glade to help
__________________
Bob
94 aerostar 4.0
92 c150 351w
88 f250 460
  #11 (permalink)
Old 01-12-2008, 02:47 PM
second chance second chance is offline
second chance is starting off with a positive reputation.
Moroso makes a wire loom kit for 5.0 Ford, that's what I used when I put the 8.8 300+ Accels on my 95.Got mine at a local speed shot for 9.95.
  #12 (permalink)
Old 02-23-2008, 06:02 PM
alien4fish alien4fish is offline
alien4fish is starting off with a positive reputation.
i need the firing order for a 4.9 300cid, any one have the layout?
  #13 (permalink)
Old 02-23-2008, 06:30 PM
quicklook2's Avatar
quicklook2 quicklook2 is online now
quicklook2 has a very good reputation on FTE. quicklook2 has a very good reputation on FTE. quicklook2 has a very good reputation on FTE. quicklook2 has a very good reputation on FTE.
Quote:
answered already in your other post.
__________________
"To believe is to know you believe, and to know you believe is not to believe." ~ Jean-Paul Sartre
  #14 (permalink)
Old 03-09-2009, 08:44 PM
95gearhead 95gearhead is offline
95gearhead is starting off with a positive reputation.
Post 5.8lightning engine swap into5.0 place
I am looking to find a 5.8 lightning engine to put in my 95 F150 project truck. Anyone got any info? will the transmisssion bolt up? both trucks are 2wd, but my truck is supercab.tranny is aode.
  #15 (permalink)
Old 03-25-2009, 12:09 AM
Mr. M's Avatar
You can buy a lightning shortblock from svo for about $1700. However, I would hesitate for you to mate that behind an aod-e. Unless you are fluent in the binary code utilizing TweeCer or Moates QH. There may be a mustang binary code that you could tweak to make it work... but it will be on your shoulders to beta test it.
If you are set on a the lightning block setup...you would be best off finding a rebuildable e4od tranny core ($250-400) (make sure it is a small block bellhousing as well) and swap the lightning block at the same time. A lightning ECU is a cheap find if your savvy in junk yards or ebay. The lightning SD ecu will tame the motor and tranny in tandem. If it wasn't an electronically controlled AOD... you would have many many more options.
The only tricky part of this swap will be finding a driveshaft of correct length. This is secondary to having the motor and tranny behaving together, and properly, in my opinion. Worst case scenario... a custom length driveshaft might leave you $300 more in parts.
A mismatched tranny, motor, ecu logic, you name it... can you leave you much deeper in the pockets.
My $.02
Good luck sir.
__________________
94 F150 XLT
Tags
50 , ford , plug , routing , spark , wires
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
