Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 06-14-2007, 12:19 AM
seetwisted is starting off with a positive reputation.
I put my heat shield on the header so heat would not be transferred into the starter housing.and the shield is two-piece,about a 1/4'' space between the two, so one shield/plate blocks heat,the air gap carries off heat,the 2nd plate blocks anything left. And as I've mentioned in the telling to other times...the outer plate never got hot enough to cure the header paint. I should have done something with my motormounts though,cause it looks like the heat is cooking the rubber pretty good...
Sponsored Links
To remove this ad, register today!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
