2000 F150 Rear Brakes problem? - Ford Truck Enthusiasts Forums
Old 08-05-2002, 11:01 PM
copeina's Avatar
copeina copeina is online now
copeina is starting off with a positive reputation.
Old 09-17-2002, 05:52 PM
rootdenied rootdenied is offline
rootdenied is starting off with a positive reputation.
Hello everyone. . .I have a rather baffling question/experience to share with anyone so hopefully I can solve it. My ABS light occasionally come on in my truck, but turning the engine off and then back on makes it go away. I thought nothing of it till recently. Over the weekend I had my truck parked in the backyard because of street sweeping on Mondays. I go to pull my truck out and drive down the alleyway and press lightly on the brakes and the ABS engaged and I skided a bit a short distance. I felt the brake peddle pulsate like I slammed on it really hard but I did not. I did nothing to the rear end of my truck over the weekend. I pulled my front wheels off to investigate some clicking up front, but I did nothing at all in the back portion of my truck.
Now just today I pull out of my schools parking lot and made a right hand turn onto the main street at about 10 to 15 mph. During the course of the turn I went through a puddle of water. AFTER I went through the puddle my wheels skided a lot. Its really unexplainible because I was looking through my side view mirrors and I was not in the water at all at that point. So I need some help here.
I suspect my ABS sensors but the light only illuminates occasionally. So I need some advice on this.
Thanks!
Old 09-17-2002, 11:32 PM
aldridgec's Avatar
aldridgec aldridgec is offline
aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.aldridgec has a very good reputation on FTE.
Do you have drum or discs in the back. If you have drums it could be a leaky axle seal slobbing up the shoes and causing the drums to grab. I assume the back brakes are locking up. If its the fronts, and your abs light is coming on it could be a modulator problem. Its really hard to know why the abs light is coming on without a scanner to see what kind of codes it is setting.
Old 09-18-2002, 01:10 AM
Yes I do have drums on the back, and thats where the problem seems to be occuring. However, I am unable to reproduce it all, until it catches me totally off guard. What other symptoms would there be of an axle leak? Would I see a lot of lubricant on my rims or anything like that?
Old 09-18-2002, 10:56 AM
white99 white99 is offline
white99 is starting off with a positive reputation.
Post 2000 F150 Rear Brakes problem?
My truck would do the same thing after any 4x4 trip. I would loosen the back shoes and that would stop it. I finnally took it to the shop and the rear drums were out of round. Didn't believe it at first till my last 4x4 outing and it didn't happen any more.
JimP
Old 09-18-2002, 04:14 PM
lm1d lm1d is offline
lm1d is starting off with a positive reputation.
you probably have an issue with an ABS sensor on the rear brakes. Check your codes and replace the sensor as necessary.
**** bradphx 1973 - 1979 F-100 & Larger F-Series Trucks 59 12-05-2016 04:27 PM
Can someone explain this to me? 1987 - 1996 F150 & Larger F-Series Trucks 11 03-09-2016 01:40 PM
ooops Aerostar 5 01-14-2015 04:16 AM
... miko6810 Modular V10 (6.8l) 9 06-04-2014 07:14 AM
DPSE Roachfood 1987 - 1996 F150 & Larger F-Series Trucks 3 03-11-2002 11:21 PM
Tags
2000, 2000f150, 2002, 2002f150, 4x4, abs, back, brake, brakes, f150, leak, light, rear, rotors, shut, z2267
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
