4 wheel drive low range. - Ford Truck Enthusiasts Forums
Old 06-06-2007, 02:22 PM
skilife17's Avatar
skilife17 skilife17 is offline
skilife17 is starting off with a positive reputation.
I have been wondering is there a way I can safely stop the front axle from engaging when I select 4L? I am going to be pulling a trailer on Friday and would like to use the low gearing of low range to help with backing up an incline to an entrance. I looked under the hood and it looks like I can disconnect the electrical connectors from the vaccum solenoids. If it is possible to do it what one would I disconnect for temporary use?
Old 06-06-2007, 03:06 PM
BURNSTOUGHFORD's Avatar
BURNSTOUGHFORD BURNSTOUGHFORD is offline
BURNSTOUGHFORD has a good reputation on FTE.BURNSTOUGHFORD has a good reputation on FTE.
Why not leave the 4wd in and use all four to push it backwards?
If not that just pull the front drive shaft... shouldnt be to bad..its bolted on with flanges on both ends i think
Old 06-06-2007, 05:52 PM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
i would use the 4 x 4, but if you want to disconnect, how about looking at the axle vacuum cylinder and disconnect the hose at the bottom, or follow it up to the motor and pull and plug it up there. i dont know which hose it is right now.
Old 06-06-2007, 06:25 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
I saw this on eBay and considered it to repair my broken shift diaphram mount but it is a little pricey for what you get IMO. It will do what you want though. Check it out.
4x4 Posi-Lok AXLE DISCONNECT System 97-03 Ford F150 4WD
http://cgi.ebay.com/ebaymotors/4x4-P...QQcmdZViewItem
Old 06-06-2007, 07:05 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
The reason you want 4lo gearing but not 4 wheels turning is to make it easier to turn, when you are backing up with a trailer you will at times turn the wheels all the way and it is a PITA if they are engaged, as well as hard on the front end. That is the biggest benefit to manual hubs. The only way I can think of is finding the right fuse to pull for the vacuum pump or some other thing in the systems that you can kill.
Old 06-06-2007, 11:13 PM
tim.moman tim.moman is offline
tim.moman is starting off with a positive reputation.
I miss locking hubs just for that use.
Don't know how to do up top, but disconnecting the hoses on the axle will do what you wish. Easily done as well. Just plug to keep dirt out. I ran 2k miles without any issues of the front trying to engage. The transfer case will still engage to the drivers tire, but the spiders gears will turn freely since the pass tire is not connected.
Never thought of inserting an overide on the controller. a switch inside to disable the change and hold in 2wd setting would be slick.
Old 06-07-2007, 01:24 PM
ncranchero's Avatar
Quote:
And a heck of a lot cheaper than that cable kit!
Old 06-07-2007, 04:51 PM
skilife17's Avatar
I took a look under the hood and was thinking that maybe disconnecting the plugs from the solenoids to prevent the front from engaging.
I did decide to look in the owners manual and just pull the relay that controls that but it also controls other functions.
Old 06-07-2007, 05:36 PM
ncranchero's Avatar
PM me your email address and I'll send you the schematic for the axle shift solenoids. The solenoid with the light blue plastic line is the one that engages the front axle. The pink line disengages it.
Old 06-08-2007, 05:18 AM
ncranchero's Avatar
Since several have expressed interest in having the schematic I'll post it here.
Old 06-10-2007, 12:34 PM
skilife17's Avatar
I would like to thank you all for the help. I was able to disconnect the front axle and it worked wonderfully. The low range gearing helped greatly in backing the trailer up the ramp. So again a big thanks to those who helped and ncranchero for the schematic of the front axle system.
Jason.
Old 06-10-2007, 02:27 PM
ncranchero's Avatar
Quote:
Jason.
So where did you end up disconnecting it? I haven't tried it yet, wondering what worked for you.
Old 06-10-2007, 02:49 PM
skilife17's Avatar
Quote:
I just unplugged the connector on the solenoid on the right side looking from the front of the truck. It simpler terms I disconnected the one with the light blue line coming out of it.
Old 06-10-2007, 02:54 PM
ncranchero's Avatar
Simple enough! I might have to add a dash switch for that. I miss not having locking hubs but haven't run into a problem yet. Better mod it before I do.
Old 07-08-2007, 03:13 PM
ncranchero's Avatar
I put my vacuum motor back on yesterday and it wouldn't engage the front axle. Fords wiring/vacuum diagram I posted is wrong!! The blue line goes to the back of the actuator/motor and the pink line goes to the side with the plunger! Works great like that! Sorry for the wrong info but it was from FORD not me.
2wd low range? luv70sfords Ranger & B-Series 7 06-04-2016 05:08 PM
reduced power in low range eberlestock 1999 to 2016 Super Duty 7 04-16-2015 12:40 PM
1999 F250 Super Duty stuck in 4x4 low range cassenbl 1999 to 2016 Super Duty 4 04-24-2007 09:17 AM
BW 1356 for 2WD Low Range? Argo Clutch, Transmission, Differential, Axle & Transfer Case 5 07-31-2004 08:13 PM
86 Bronco II 4X4 Inop MJB Bronco II 9 11-21-2003 09:53 PM
Tags
2003, 2wd, 30l, 4x4, 73, 97, axle, diagram, disconnect, engine, escape, ford, posilok, system, v6, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
