360?
Originally Posted by 1975Ford
This friend of mine Dad had a factory 360 4bbl with an automatic transmission on a 1976 Ford F150 2wd LWB. The truck ran like a champ and had plenty of power. The truck was sold about 20 year ago.
My brother-in-law rebuilt a 360 on a different 1976 F150 2wd LWB with an automatic transmission and he installed an RV cam and dual exhaust but kept the original 2 bbl carb. This truck had gusto and ran like a champ.
I had a 360 cid FE on My 1976 F150 4x4 SWB and rebuilt the engine to a 390 FE with other upgrades https://www.ford-trucks.com/user_gal...136765&width=0.
If you planning on rebuilding the engine, this might be an option "360-390- 410"
Duraspark ignition on these engines make the engine run better too.
This truck must of been special ordered with a 4 bbl. This 360 FE had the factory 4bbl intake and carb. There was no modification done to this truck.
Originally Posted by Bear 45/70
There was never, ever a factory 360 with a 4 barrel. Every one was a 2 barrel.
Originally Posted by blastmaster
Okay, if I may ask, where did you get that information? The reason I ask is that I just got a 65 F250 and the VIN comes back as a 352 with a 2-barrel, but I can see a 4-barrel factory manifold with an adapter plate with a 2-barrel carb is attached.
I think maybe I came off sounding diferrent than I intended, sorry. I wasn't questioning the validity of your statement, Bear 45/70. I wanted to know the source so I could research my vehicle. I appologize if I sounded like I was bringing out the hatchet...
Anyway, the history of this truck is short. My father in law gave the truck to me. It sat parked for several years after the original owner, his brother, passed away and left it to him. My father in law swears he knows for a fact this is the original engine, and it was rebuilt twice, but never exchanged. I would not of thought otherwise, except that I noticed significant modifications, such as the aftermarket adapter plate, some headers and air cleaner. I made an assumption that, being a F250, the engine was probably a 360, less likely a 390, and the modifications were the result of an attempt at better gas mileage. I ran the VIN and discovered the original configuiration is quite diferrent from what I expected, then read your post, Bear 45/70, and concluded my FIL was mistaken, and the engine was likely swapped at some point. I'm curious to know what engine it might have now. The source of your information might tell me what FE engines came with a factory 4-barrel, and that may give me a clue to start with, before I measure stroke.
Again, sorry for coming off like an @$$, it was totally unintentional.
More info - The 360 is mainly a de-stroked 390. The difference is the rotating assembly (crank, rods, pistons ) When I rebuild my 360-4V, I'm boring to .040 over and changing to a 390 crank and rods but getting a new set of 360 pistons. With an RV cam and a 1' spacer under a 700 Holley and with long-tube headers, I should notice a BIG difference. For my $$, that's the biggest bang for the $.
#29
#30
