Rear Excursion Differential - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 06-05-2007, 09:46 PM
vettdvr's Avatar
vettdvr vettdvr is offline
vettdvr is gaining momentum as a positive member of FTE.vettdvr is gaining momentum as a positive member of FTE.
Ok Could not find this in a search,, but does anyone know what type of diff is in the rear of a 4WD 7.3 2000 Excursion. Is it the Dana 80? Thanks Jim
Old 06-05-2007, 10:11 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
Should be a 10.5" sterling.
Old 06-06-2007, 01:15 PM
njstevens's Avatar
njstevens njstevens is offline
njstevens is starting off with a positive reputation.
I concur with ReAx on that. I don't believe they used anything different. Why are you asking?
Old 06-07-2007, 08:38 AM
vettdvr's Avatar
Quote:
I am planning to service (oil) my diff and want to be sure the oil meets the spec and limit slip requirments. When I look at my manual it gives 3 differentials and I found labeled Sterling. So it becomes confusing when you want to insure you have the right spec oil/lubes. JIm
Old 06-07-2007, 12:21 PM
71-4R3SONS's Avatar
71-4R3SONS 71-4R3SONS is offline
71-4R3SONS has a good reputation on FTE.71-4R3SONS has a good reputation on FTE.
Royal Purple
I just put this 2008 diff cover on my 2005... same should fit your X. As far as what type of rear diff fluid I used ROYAL PURPLE 75W-140... RP has the friction modifiers needed for a "limited slip" included in it's formula. As long as you're changing the fluid why not do a rear cover swap too!!
Have fun... I did!
Old 06-07-2007, 04:21 PM
1's Avatar
1 1 is offline
1 is gaining momentum as a positive member of FTE.1 is gaining momentum as a positive member of FTE.
10.25 or 10.5 it seems to be a guessing game as to which you may have. Pretty much the same thing other then the rig gear is a bit bigger i hear. Still dont get how this is possible, seems wrong.
Old 06-07-2007, 05:57 PM
ReAX's Avatar
There was a year split, the 99+ superduty/excursion should be either the 10.25 or 10.5. For diff cover's the pattern is the same. I think the gears were the same, I thought that motive used the same PNs for both diffs.
I used a mag hy-tech diff cover and Royal Purple when I had my gears done a couple weeks ago. No noise from the LS, and I haven't used any additives yet.
Old 12-30-2009, 09:34 AM
ehp2976 ehp2976 is offline
ehp2976 is starting off with a positive reputation.
What 2008 Part Did You Use??
Hi,
You guys have put a lot of really good stuff in here and I've got the same
prob with my 2000 Ex with the rust at the bottom of the diff cover and I've
seen a '08 part referred to a couple of times but which part do I order from
Ed the parts guy? Do I look for a 2008 F250 diff cover or something else??
Thanks, you guys are awesome!
Old 12-30-2009, 10:11 AM
housedad's Avatar
housedad housedad is online now
housedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputationhousedad has a superb reputation
It is listed right on the front page of Ed's site.
www.partsguyed.com
$50.15 plus shipping.
BTW, I usually make fun of guys that dig up ancient threads, but seeing as you are new here, I won't have a go at ya!
Old 12-30-2009, 11:44 AM
Parts Guy Wyatt's Avatar
Parts Guy Wyatt Parts Guy Wyatt is offline
Former Vendor
Parts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud ofParts Guy Wyatt has much to be proud of
you will need to go to hardware store and get longer bolts also, Ford wants way to much for theirs.
Old 12-30-2009, 12:02 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy X_Hemi_Guy is offline
X_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputationX_Hemi_Guy has a superb reputation
Man...this IS a REALLY old thread! LOL
When I did my cover I went with stainless steel hardware I bought 12 longer bolts with washers and lock washers (5/16-18 x 1.25)for maybe $1.00 each from my local hardware store...I can't remember the actual price for the hardware but it wasn't all that much when you compare to what Ford wanted for non stainless!!!
Joe.
Old 11-17-2013, 12:21 AM
Trucks Unlimited's Avatar
Trucks Unlimited Trucks Unlimited is offline
Trucks Unlimited is starting off with a positive reputation.
Joe.
Yea yea, I'm posting on an ancient thread. I need to know; are the bolts partial thread?
Old 11-17-2013, 03:48 AM
Skip1970's Avatar
Skip1970 Skip1970 is offline
Skip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputationSkip1970 has a superb reputation
thats a nice rear cover!
Old 11-17-2013, 08:14 AM
WE3ZS's Avatar
WE3ZS WE3ZS is offline
World Famous Mod
WE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputationWE3ZS has a superb reputation
Quote:
They can be, it doesn't really matter. The extra length is needed because the factory cover is just thin sheetmetal and the '08 aluminum cover has thicker pads at the mounting flange, so the section of bolt just under the head (threaded or not) is inside the new cover holes in the thick section.
I can't remember what style my stainless socket head cap screws were.
Old 11-27-2013, 02:33 PM
Oelfke Oelfke is offline
Oelfke is gaining momentum as a positive member of FTE.Oelfke is gaining momentum as a positive member of FTE.
I know this thread has been dead for awhile, but I am looking to install the 08 Rear Differential cover on my 00 Excrusion 4x4. I just wanted to know how long of bolts do i need to pick up?
February 2015 all topic thread Nighteyez N. California Chapter 118 03-02-2015 05:01 AM
Injector Cleaners hammer65 1999 - 2003 7.3L Power Stroke Diesel 24 08-07-2014 05:40 PM
A/C leak on 2000 Excursion Jim Hughes Excursion - King of SUVs 0 04-30-2011 06:00 PM
2000 EXCURSION AC LEAK Jim Hughes 1999 to 2016 Super Duty 0 08-10-2010 12:00 AM
Excursion Die Cast Jim Hughes Excursion - King of SUVs 2 03-07-2007 11:01 AM
Tags
08, 1025, 1999, 2003, 2005, aluminum, cover, dana80, differential, excursion, f150, ford, limited, rear, slip, swapping
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
