Rear Excursion Differential
I changed my cover awhile back as well and went with mobil 1 75w140 LS diff fluid.
I found out that my rear cover was leaking a bit not from rust but from the differential contacting something and raising a lip in the cast metal on the bottom causing the leak.
So after filing down the hill and doing all the work and installing new cover I took the old cover which (was still good) and used it to replace the rusty cover on our 94.5 F250.
Yes it will, whether you have the 10.25 or 10.5 rear. You're good to go. Carry On Wayward Son...
Thanks again for all the help
Should be a good weekend project.
Ordered everything on ebay. With the cover and 4 liters of Royal Purple 75w-140 price will still be on under $150 with a new gasket and some Permatex Ultra Black, bolts, etc.
4 Liters Royal Purple (Ebay Item #281207108410) $72.29
Permatex RTV Gasket (Ebay Item #271245979142) $4.59 + Shipping
Aluminum Diff. Cover (Ebay Item #300550951896) $53.83
FEL-Pro -Gasket (Ebay Item #350840960213) $7.24
10 Pack of Bolts (need 12 total) (Ebay Item# 231085796889) $8.14
Doesn't have anything to do with Differntials but for $185 a piece I ordered two new Optimas D34/78 (ebay item # 190965601058)
Also got a new Driver Side Window Motor for $30.
I love saving money and ebay is my #1 place to save right now. Also they have ebay bucks which gives you 1-3% back on all your purchases. All of the items above have more available if anyone else was looking to do this project.
#28
