Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Ford V6 > 2.6, 2.8, 2.9, 4.0 and SOHC 4.0 V6
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-05-2007, 08:13 PM
4xFordFreak is new and has a neutral reputation at this point.
2.9 EGR Valve
How does the EGR valve operate on the 2.9? At cold start up should I have pressure on the sensing line on the EGR? When will there be vacuum on the vacuum line? I have a code for low voltage on the egr. the truck runs great for the first 40 miles then starts to stumble. Any and all help would be appreciated.
__________________
If You Aint't been STUCK,
You Ain't been 4wheeling
1987 Bronco 5.0 auto c6
1987 Ranger Super Cab STX 2.9 5sp
electronic shift 4x4
2007 Chevrolet 2500HD Classic CC 4x2 Duramax/Allison
(Company work truck that just replaced 08 psd)
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-06-2007, 12:03 AM
mrshorty is starting off with a positive reputation.
I find that the first step in diagnosing any EEC-IV trouble code is to identify which type of code it is. Was it a KOEO (hard fault) code, KOER code, or CM code? This can be important because a KOEO code (which is set with the engine not running) almost always has to be electrical. A KOEO EGR code wouldn't have anything to do with vacuum.
As for basic operation. The computer monitors the voltage from the PFE sensor (Pressure Feedback EGR). Above idle, the computer tries to maintain a certain sensor voltage via a pulse-width modulated signal to the EVR solenoid (EGR vacuum regulator). When the voltage is high (indicating high back pressure), the computer increases the duty cycle on the EVR solenoid to open it, and the EGR valve, more. When the signal goes low, the computer closes down the EVR solenoid and allows the EGR valve to close.
__________________
'87 Bronco II XLT 4x4 & '92 Explorer XLT 4x4 & '98 Chev Suburban K1500 SLT 4x4
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
