57-60 f100 sway bar?
Old 06-05-2007, 12:56 PM
qorray's Avatar
qorray
qorray is offline
Does anyone have any sources for 57-60 sway bars? These trucks have some of the worst side 2 side sway that I've seen. I still love my truck though, just trying to make it handle a little bit better!!!. Boss auto products makes a rear sway bar for these trucks but it's $239.00, whoa. Thanks
Old 06-05-2007, 01:12 PM
qorray's Avatar
qorray
qorray is offline
botp has a rear also for 134.95. Still looking for a front though.
Old 06-05-2007, 01:44 PM
Max E's Avatar
Max E
Max E is offline
sway bars
Niether of you said if you are stock or with a MII crossmember but Vintage Ford has both , front $180 (#7376 stock) (MII# 7377-1 $160)rear $175 #7377 bolt on 48-62.
I have seen others for about the same price.
Max E
Old 06-05-2007, 01:46 PM
kooper909's Avatar
kooper909
kooper909 is offline
Will these sway bars work on lowered stock running gear?
For example, I plan on dropping my axle and getting mono leaves ... will the sway bar work on that setup?
Old 06-05-2007, 01:53 PM
Max E's Avatar
Max E
Max E is offline
The front says stock or mono leaf springs. Don't mention dropped. that MII # is with stock A arns /tubular A arms is 73377-2 $180.
THere number is 1-888-FORD100 Check the numbers and prices this is an older book
Max
Old 06-05-2007, 01:54 PM
qorray's Avatar
qorray
qorray is offline
I'm running a stock straight axle on my 59 panel but like cooper909 I'm going with the monos in the front. Thanks
Old 06-05-2007, 02:02 PM
qorray's Avatar
qorray
qorray is offline
That 7376 # refers to a 53-56. I didn't see a front sway bar for these truck but that rear is pretty sweet.
Old 06-05-2007, 04:39 PM
Max E's Avatar
Max E
Max E is offline
If you call them they might be the same for all the straight axles
Max
black58
02-18-2012 08:58 PM
58tow
02-24-2006 02:08 AM
Bennyteee
05-10-2004 09:26 PM
monster86f250
05-20-2001 07:17 PM
Mark Hendricks
10-07-1999 02:29 PM
Quick Reply: 57-60 f100 sway bar?
