97 f150 third door - Ford Truck Enthusiasts Forums
97 f150 third door
Old 06-05-2007, 10:12 AM
hungry_aggie hungry_aggie is offline
hungry_aggie is starting off with a positive reputation.
97 f150 third door
my third door will not open you can pull the handel up but it does not unlatch is this a cable system or a rod system. how do you pull the door panel off to fix this problem.
Old 06-05-2007, 05:16 PM
ncranchero's Avatar
ncranchero ncranchero is offline
ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.ncranchero has a good reputation on FTE.
Looks like some of both. Photo courtesy of Ford Tech Resources.
Item Part Number Description
1 Upper Rear Door Latch
2 Inside Rear Door Handle
3 Rear Door Inside Handle Remote Control
4 Rear Door Latch Remote Control
5 Lower Rear Door Latch
6 Outside Rear Door Handle
Old 06-06-2007, 02:19 PM
UtilityCow's Avatar
UtilityCow UtilityCow is offline
UtilityCow is starting off with a positive reputation.
Just took mine apart. My cable broke. It is really a lame design. Puts a lot of pressure on the cast plastic end of the cable case. I'll try to find a new one or rig the old one to work. Let us know if you got the same thing and a solution.
Old 07-13-2007, 10:23 AM
Sandbar Norm Sandbar Norm is offline
Sandbar Norm is starting off with a positive reputation.
I'm having the same problem. The upper latch will not release. As far as taking it apart, how do you do that. Mine looks like outside door latch is riveded. Just drill out or grind the off or what? I dont see anyway to remove the inside latch. How do you get the upper latch to release to open the door?
Old 07-14-2007, 03:28 PM
UtilityCow's Avatar
I removed the door panel from the back seat with no problems. Peel back the plastic vapor barrier and everything is right there attached to the inside door release.
If you need to get the door open, pull on the end of the cable while pulling on one of the door releases.
All I had to do was put the cable back in it's holder and it's lasted 10+ openings. I put the panel back on and haven't worried about it. If it falls out again I'll probably zip tie it in or something. Can't justify buying the $50+ latch assembly because an itty piece of plastic broke off the end of a cable.
Old 09-28-2011, 07:44 PM
THE GODFATHER THE GODFATHER is offline
THE GODFATHER is starting off with a positive reputation.
Thank you for this. I just read this and fixed mine in 20 minute's.It was just how you said, it came out of the holder so i put it back in and used 2 zip tie's to hold it in place.
I know this is an old thread but maybe it will help someone like myself in the future.
Old 09-29-2011, 06:43 AM
Well my has broke again.
Ford did not do a very good job on this design.
Norm
Old 11-11-2011, 11:49 PM
Ningker Ningker is offline
Ningker is starting off with a positive reputation.
Access top latch/Cable fell off completely....
Just had the same problem on my 2000.....
How do you access the top latch when the cable came off completely?
Both top and bottom latch need to be fixed. I can access the bottom real easily however can't figure out the top.
I have tried a clothes hanger up to the latch and am litterally fishing to hook on something to pull.
Any Help Please......
Old 11-12-2011, 04:49 PM
oh wow, i don't know how to get to the top latch.
Maybe somebody here will chime in and let us know.
Old 11-12-2011, 07:26 PM
Yeah, I can't figure it out. I see a scree under the weather strip but I suspect that if I loosen it up and it falls down and out the door, I see NO WAY of getting it back up into the door.
Just trying to figure out how the latch is configured in there so I know what area to fish at with the clothes hanger.....
E250 - Door Hinge Issues ParkingGuy 1968-2013 Full Size Vans 42 09-27-2016 12:57 AM
taillight issue Bsmith153 Excursion - King of SUVs 5 01-07-2015 12:07 PM
2 door convert to 3 door bava01 1987 - 1996 F150 & Larger F-Series Trucks 14 05-02-2013 06:38 PM
Truck Broken into AGAIN, Need Alarm door wiring help Shadow351 1997 - 2003 F150 4 06-28-2012 12:25 PM
Supercab Upper Latch Fix/Access Ningker 1997 - 2003 F150 4 11-29-2011 06:49 AM
Tags
06, 1997, 2000, 3rd, assembly, door, f150, f250, fix, ford, latch, opent, unlatched, upper, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
