Grille
Grille
Thinking of stripping my grille. Has anyone used this product before http://www.blulightning.com/product/ADPT ?
No...but if you do let me know how it works. I think the steps would be...remove anodized coating, buff with compound to mirror polish, and the clear with a protectant like Zoops sealer, unless someone knows of a different way to protect. Been thinking about doing the same thing to mine, but I didn't run across the particular anodize stripper.
"Oven Cleaner" I've seen it discuss on here; as well as recently use on Power
Block show Trucks. They spray it on the metal (Off the truck) and let it sit about 5 to 10 min; wipe off and then buff with a metal polish.
I would then spray a clearer to seal your highly shine finish. I personnally havn't try this; but will on my recent purchase 68 soon.
Mitch
Mitch
The oven cleaner is iffy... I used it on a piece of my 68 tailgate trim and it worked great but on the headlight bezel, it would not budge it. I recoated it probably a dozen times and let it set as much as a half-hour and there's still anodizing on it. Thanks for posting this new stuff. Keep us updated.
spots
spots
Mitch
Mitch
Under NO circumstances use oven cleaner or any lye (sodium hydroxide) based solution on anything aluminum. It'll dissolve aluminum almost instantly. (It also generates a tremendous amount of heat.) Look on some radio controlled car forums (and maybe other places) for tips on "home anodizing". It's a fairly simple process that can be done by a resourceful person.
Any aluminum that isn't attacked by lye is spared only because it's being protected by a thin film of aluminum oxide (the very thing you're trying to remove)
If you don't believe me, at least try a strong solution of lye in a pyrex dish and add a piece of scrap aluminum or some aluminum foil. If you want a more detailed explanation, please read this link...
why lye and aluminum shouldn't be mixed
I'm not trying to be a wiseguy, please don't take my post that way, I just don't want to read about someone getting hurt or damaging an expensive part.
Rawhyde
lowell75
Bio-diesel, Propane & Alternative Diesel Engine Fuels
01-13-2008 08:29 PM
