Flathead 6 cylinder.
I have a 1951 F-6 with a 254 cu. in. "M" series flathead 6,, that is cracked.. I was curious if anyone knows whether any newer OHV engines would couple to this bellhousing, or even if a newer engine/bellhousing would couple with this 4 speed transmission.. I am not concerned about mounts of any kind.. I can manufacture what that would require,, just the coulping together.. Thanks for any help anyone can give.
Ross,
The syncronized transmission was offered as an option I believe in the F-4 and up in '48 and came standard in the bigger trucks in '51. I have had a couple of bigger model '51s and '52s and they had the syncronized trannies. You can tell by the shift pattern, the non-syncro tranny shifts over and down for reverse, the syncro tranny shifts over and up. The syncronized trannies are also a bit longer.
The 300 might be a little too long to fit into engine compartment without remounting the radiator even farther forward than it is with the flat six. I don't know this for sure, I am sure someone with let us know if they have done this.
Originally Posted by ksmith203
My tranny is T98 and it shift to the right and back towards the seat. I don't believe it is a synchronized tranny. When I drive it I grind the hell out of the gears, and I usually can drive anything.
harvtown
04-22-2014 10:55 PM
Fat Fendered Ford
16
05-08-2006 07:26 AM
restoringmy46
Flathead V8 & Flathead 6
01-09-2006 10:15 PM
