New York Chapter Join Chapter, Leader: tiny1
98 f150
Old 06-04-2007, 02:05 PM
hose13's Avatar
hose13
hose13 is offline
Cool 98 f150
having problems with my 4wheel drive not disengaging,any ideas thanks
Old 06-04-2007, 09:21 PM
Ronin007's Avatar
Ronin007
Ronin007 is offline
Did you post this in the 1997 - 2003 F150 forum? I would think you would get a quicker response there.
If I remember correctly your system have a switch on the dash which can cause problems with engaging/disengaging same thing with the front disconnect unit. How those work and how you troubleshoot them I am not aware of. Hopefully someone else will come along and can shed more light on your issue than I can. Good luck to you!!
Old 06-05-2007, 01:10 PM
hose13's Avatar
hose13
hose13 is offline
thanks for the info,mine has the shifter on floor im going to crawl under to check out
Old 06-05-2007, 01:26 PM
Ronin007's Avatar
Ronin007
Ronin007 is offline
Those can bind or the linkage can come out of adjustment preventing you from getting it out of 4x4. Hopefully it is the linkage on the outside of the transfer case giving you issues instead of the linkage inside.
Let us know what you find out and good luck with it!!
Old 06-06-2007, 08:03 AM
lenny1carl's Avatar
lenny1carl
lenny1carl is offline
try backing up a short distance. sometimes that may disengage it
Old 06-06-2007, 06:06 PM
hose13's Avatar
hose13
hose13 is offline
thanks for all the ideas, think i figure it out. there is a round sleeve with a arm that goes in and out think its sticking.thanks for answering my post
Old 06-07-2007, 10:49 AM
Ronin007's Avatar
Ronin007
Ronin007 is offline
Let us know if you get it fixed or need additional help. Good luck!!
Old 06-07-2007, 05:15 PM
hose13's Avatar
hose13
hose13 is offline
thanks.ill see if i can get to it this weekend
Old 06-29-2007, 06:42 AM
hose13's Avatar
hose13
hose13 is offline
just wanted to let you know what I found out about my 4x4 problem was. It is a electric solenoid that isnt disengaging,located up front
Old 06-29-2007, 06:29 PM
Ronin007's Avatar
Ronin007
Ronin007 is offline
Glad to hear that you got it figured out.
Old 06-29-2007, 07:01 PM
lenny1carl's Avatar
lenny1carl
times like this i'm glad i've got an older truck. not all those gizmo's that would drive me psycho
04-13-2004 12:08 AM
11-12-2002 01:38 AM
01-14-2002 09:06 AM
03-11-2001 10:13 PM
Quick Reply: 98 f150
