Dodge Dakota suspension - Ford Truck Enthusiasts Forums
View Poll Results: Would an '89 Dodge Dakota IFS work on my '55 F-100?
Will a Dodge Dakota IFS fit a '55 f-100? 1 50.00%
Is a Dodge Dakota IFS a good choice for a '55 F-100 1 50.00%
Voters: 2. You may not vote on this poll
Old 06-04-2007, 12:41 PM
64Blubyu 64Blubyu is offline
64Blubyu is starting off with a positive reputation.
Question Dodge Dakota suspension
I am looking to put an IFS on my son's '55 f-100. I have heard that a Dodge Dakota is a good donor. An '89 Dakota just happens to be the first available option. Does anyone have any knowledge about this? Please help me to make a wise decision as we are building on a limited budget. Your replies, GOOD or BAD would be greatly appreciated.
Old 06-04-2007, 12:56 PM
Huntsman's Avatar
Huntsman Huntsman is offline
Huntsman is starting off with a positive reputation.
Here's a link for you
http://www.ford-trucks.com/article/i...art_Seven.html
I don't know anything about the upgrade pro or con but others will be along who can help you. Welcome to FTE!
Old 06-04-2007, 05:53 PM
eviljake's Avatar
eviljake eviljake is offline
eviljake is starting off with a positive reputation.
Old 06-04-2007, 08:54 PM
Dustin1690 Dustin1690 is offline
Dustin1690 is gaining momentum as a positive member of FTE.Dustin1690 is gaining momentum as a positive member of FTE.
Well if it works and its cheap go for it!. i guess cause everyone else uses IFS from jag volare crown vics/grand marquis and bunch of other vehicles
Old 06-04-2007, 09:47 PM
CIAF's Avatar
CIAF CIAF is offline
CIAF is starting off with a positive reputation.
I Don't Get The Poll. They Both Are Yes. What Are You Really Asking????
Old 06-04-2007, 10:17 PM
Huntfamily53's Avatar
Huntfamily53 Huntfamily53 is offline
Huntfamily53 is starting off with a positive reputation.
I say use what you have available. I have heard good things about it. I am going with the volare because that was the first suspension that I was able to find a good deal on.
Old 06-05-2007, 10:43 AM
Quote
I didn't get the quote either and then could not figure out how to delete it.
Quote:
Old 06-05-2007, 10:45 AM
Thanks
Quote:
Originally Posted by eviljake
Thanks for the website. I will check it out in detail.
Old 06-05-2007, 10:49 AM
eviljake's Avatar
No problem, I'm probably just going to buy the crossmember and get the rest at the junk yard.
Old 06-05-2007, 10:54 AM
I have a complete truck available. I am thinking of a frame clip but Not sure yet
Old 06-05-2007, 11:03 AM
tomoto tomoto is offline
tomoto is starting off with a positive reputation.
I have just put a 89 Dakota under my coe ,it rides like a new truck BUT steering will be wrong for a pick up ,it was just right for what I was doing.
Old 06-05-2007, 01:10 PM
1963f100 1963f100 is offline
1963f100 is starting off with a positive reputation.
I just received my crossmember from Industrial Chassis to put the Dakota IFS under a 63 F100, haven't installed it yet. I went with it because the Mustang II stuff is getting hard to find without going with aftermarket control arms and such. I also have a junkyard doen the road that has about 18 donor Dakotas just waiting for me!
Old 06-06-2007, 10:38 AM
AZAV8 AZAV8 is offline
AZAV8 is starting off with a positive reputation.
I am very familiar with Steve at Industrial Chassis. They are doing a lot more with the Dakota front crossmember and kit. Talk to Steve and he will give you the straight scoop. I am going to have him do the crossmember install for me as I don't TIG weld and this is the structure of the truck. I bought a Dakota front clip for $200 so I have all the parts to use and a frame piece to sell for scrap. I'll take my frame to Industrial Chassis later this summer for them to weld in their Dakota crossmember.
I would recommend you NOT go a frame clip graft to your truck frame. Getting the frame clip aligned to the rest of the stock frame is very difficult if you don't know what you are doing.
Phil
Old 06-06-2007, 11:29 AM
f1fordguy's Avatar
f1fordguy f1fordguy is offline
f1fordguy is starting off with a positive reputation.
I have a 95 Dakota that I use occasionally and the turning radius is slightly inside of the Queen Mary. Correct me if I am wrong (not surpriseing!) but won't this install keep the stock Dakota turning radius? I have never seen any comments on this but I would appreciate any observations from a user.
Tim
Old 06-06-2007, 12:55 PM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.GreatNorthWoods has a great reputation on FTE.
Quote:
Tim
That seems strange. Usually the turning radius is dependent upon the length of the vehicle...the shorter the vehicle the smaller the radius and vice versa. We put a Pacer suspension under a friend's 34 Pontiac about 20 years ago and it had a very short turning radius, much shorter than the original knee action suspension.
The turning radius was so short on that car he occasionally hit himself in the rear bumper...
Dodge Dakota IFS Larryjr03 New Member Introductions 2 03-18-2014 04:03 PM
Dodge dakota chassis swap. troy77 1973 - 1979 F-100 & Larger F-Series Trucks 13 08-29-2012 04:43 PM
schooling on IFS SixtySix Ford 1961 - 1966 F-100 & Larger F-Series Trucks 10 09-24-2010 10:11 AM
Dodge Dakota IFS / Frame Swap Mr. N 1948 - 1956 F1, F100 & Larger F-Series Trucks 8 04-18-2009 10:46 AM
'06 Dakota is UGLY! jbabbler Ford vs The Competition 28 03-15-2006 06:09 AM
Tags
1948, 53, chassis, clip, dakota, dodge, donor, f100, ford, frame, front, ifs, industrail, suspension, swap, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
