2001 Supercrew 5.4 Problem - MISS - HELP!!!!!!
Old 03-30-2011, 09:59 PM
FORDTRUCKS4488's Avatar
FORDTRUCKS4488
FORDTRUCKS4488 is offline
Exclamation 2001 Supercrew 5.4 Problem - MISS - HELP!!!!!!
I found the issue, there was break in the back fuel injector wire, I went to the junkard and found plug that was the same. $10 fix! BUT WAIT! The miss is gone, Started the truck up, And now theres a knocking noise coming from the driver side around the egr valve somewhere, I thought it could be the Egr Valve and its not I tested that. So I just unhooked the plug from the EGR and I am driving it like that for now. Any help for my bad luck!? TPS? IAC? Anything? Thank you guys for the help!
Hello Everyone,
So I bought a 2001 Supercrew Lariat and had it for about two weeks now. It recentley started misses around 2000rmp and up. I have tried just about everything what a pain. And of course NO code came up. Heres what I tried to far
1. Replaced all (8) Coil Packs
2. Replaced all Plugs and torqued to factory specs
3. Changed the fuel filter.
and still same freakin problem. I was reading on the internet about PCV valves and IAC valves possibly as the culprit. Also injectors maybe? Any help would be greatly appriacted. THANK YOU!!!!!!!
Old 03-30-2011, 10:07 PM
steve(ill)'s Avatar
steve(ill)
steve(ill) is offline
you need to drive it and play with the throttle and eventually get a code... anything else is just a guess... COPS was a good choice for a guess.
Old 03-30-2011, 11:05 PM
RoyalFord's Avatar
RoyalFord
RoyalFord is offline
if it idles fine then it is prolly not the IAC
Old 04-01-2011, 08:57 AM
96f150's Avatar
96f150
96f150 is offline
Where did you get your coil packs from? what I mean is, are they brand new?
Rich
Old 04-01-2011, 09:08 AM
welbo97's Avatar
welbo97
welbo97 is offline
Back when I was having frequent coil failures, I could sometimes force it to generate a code by holding the brake in drive and getting the rpm up until it started to miss badly.
Old 04-01-2011, 10:27 AM
FORDTRUCKS4488
FORDTRUCKS4488
And BTW thanks again I really do app. the help!
Jrbursee
05-09-2014 04:24 PM
RGrimes
1997 - 2003 F150
02-07-2006 12:36 PM
jeff_anderson
1997 - 2003 F150
23
05-05-2005 12:06 AM
sayce
Modular V8 (4.6L, 5.4L)
19
12-07-2004 03:24 PM
85rangerman
1983 - 2012 Ranger & B-Series
08-01-2002 04:38 PM
Quick Reply: 2001 Supercrew 5.4 Problem - MISS - HELP!!!!!!
