You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I am still working some kinks out of my B2 and tonight the dome light decided it does not want to shut off. I have checked all the doors and hatch to make sure they are closed tight. And I have checked all the plungers. I puleed the fuze for now but I was wondering if anyone has ever had this problem and where do I start? Thanks in advance.
Turning the headlight switch **** all the way to the left activates the dome lamp.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
OOPSIE! I have forgotten that I had turned it on with the headlight switch before... that's usually the first thing I check now. Hopefully, that's it. If not... time to start pulling switches and checking wiring.
__________________
-1987 Bronco II XLT 2.9L V-6 5-Spd 4x4 'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
-1989 Bronco II XLT 2.9L A4LD 4x4
-2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD (K&N air, all else is bone stock!)
-1994 Chevy 2500 5.7L 5-speed
From memory doing it a few years ago on Rangers/Explorers (might not apply to BIIs), take the cover off the lamp, if there is a little arm, bend it up slightly.
If the door switch is bad (thankfully not in the handle) it costs about $2 to replace it.
rebo, the older BIIs and Rangers didn't have a switch on the lamp assembly itself, if that is where you were going with your suggestion. I have a feeling that one of the door switches (more than likely it's the driver's side or the liftgate) is bad or there is a short somewhere in the wiring.
__________________
Check the rear plunger on the hatch..mine used to come on and that's where the problem was. Even though the hatch was closed the switch wasn't working properly. I just took out the switch. The light still works when the drivers and passenger door are opened. The rear cargo light also has it's own button on it to turn it off/on with the rear hatch opened.
__________________
-Jeff
86 Bronco II 4inch suspesnion lift, 3inch body, 35x12.50x15 BFT AT/s and 4:10gears.
05 F250 Superduty Diesel--tows the BII to the trails
Thanks for the info guys. I'll work on it some more tommorow. Somethings gotta be going on with it though, I went back out and messed around with it some tonight. Now my radio doesn't have power. It is an after market CD player but I bought the harness kit for it. I dont like hacking into factory wiring. As far as a short in the wiring I definately need to look into that more. Last week I turned the defrosters on and the blower motor made a heck of a racket, then poof smoke through the vents. I pulled the motor off to find a mangled mouse in the heater box, and enough corn to plant half an acre. I'll have to see if I still have a wiring diagram for B2's and go from there.
Yeah, actually, as Jeff mentioned, the liftgate switch tends to get messed up, or the retainer breaks off, so it sends the signal to the circuit to turn the lights on and they stay on. I forgot about that (uh, DUH, that's why mine was removed by the previous owner!). Sounds like you may have a blown fuse on your radio and that you'll need a new blower motor for the a/c - heat. Gotta love daily drivers that turn into projects! Hope you get 'er all fixed up soon.
__________________
Both my 89s had the same trouble. I had to replace the plastic on the latch post on one and the other the lift gate was so far out of adjustment it wouldn't latch and to top it off that one the gate was cracking out at the hinges. half the time i'd just pull the bulb due to frustration.
__________________
99 F-350 Super Duty 4X4
96 Windstar (the wife's)
93 Tarus GL Station Wagon (Any one want it it's free)
I Love the smell of Diesel in the Morning, It's the smell of $$$$$$$
