Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Y-Block V8 (239, 272, 292, 312, 317, 341, 368)
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-03-2007, 06:34 PM
e william's Avatar
e william is starting off with a positive reputation.
rear diff gears (Ring&Pinion)
the rear diff behind my 239-Y is a stock 1954 "292".....what gear change is possible for replacement to fit the case and give good performance, looking for a good midrange for stop light takeoff and highway speeds...?
If known, what is a good vender for the replacement parts..
thanks, Ed
__________________
What Mama Don't Know....Keeps Daddy Out Of Trouble !!!
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-03-2007, 06:54 PM
pcmenten is starting off with a positive reputation.
Not any easy choices
Your rear axle is a spicer/dana rear end, known now as a Dana 44. I'd recommend removing the rear axle and replacing it with a 1957-1970 F100 rear end. That would be a 9" rear end and the usual ratios in trucks are 3.5, 3.89. Try this article here on FTE. Rear axle article
__________________
Best regards,
Paul Menten
  #3 (permalink)
Old 06-04-2007, 10:15 AM
wild.bunch's Avatar
wild.bunch is starting off with a positive reputation.
PC's advice is probably the easiest way to go. I cannot recall the "cutoff" figure off hand, but I believe that ratios less than around 3.7 to 1 in the Dana 44 rear end requires a different carrier. For example, I have a carrier that came out of a 1951 or so Ford automatic car (I think) and it has a 3.31 gear set. I bought it for the same reason you are asking your question. But to find the necessary gears, while many cars and light trucks used the Dana 44 axle, they usually have different pinion splines. This leads into a whole 'nother mix and match issue, if the stock differential yoke cannot be used.
I think, in the end, it is just easier to go to the 9" rear end.
The trick to this is getting the spring clamps from a 57 to 60 truck, since these were the only years that used the 9" rear end where the shock mounts are on the spring clamps. In 61 and later, they mount directly to the axle tube. You can use the axle from the later truck, but you need the 57 - 60 clamp to mount the shocks.
And then, of course, you have to have the driveshaft lengthened for the 9"
__________________
My Little Y Block Page
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
