Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Explorer, Sport Trac, Mountaineer & Aviator
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-02-2007, 10:07 PM
jonm61 is starting off with a positive reputation.
99 X Front Brakes HELP!
I just changed both front calipers and hoses; now the pedal goes to the floor and only the rears are grabbing! We bled the front brakes with the engine/ignition off and everything was fine. Started the truck and the pedal went to the floor. Bled all 4 calipers and still the same problem.
Any experience/suggestions with this?
Thanks!
Jon
__________________
Jon
'99 Explorer 4Dr
4 x 2 4.0 OHV, 5 Sp Manual
Go Gators!
"It's great...to be...a Florida Gator"
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-03-2007, 09:26 AM
DMB DMB is offline
DMB is starting off with a positive reputation.
Did you get fluid to come out the front bleed screws? If no, you've still got air. If yes, it's probably either the caliper slides hanging up or the piston itself. Make sure the caliper slide bolts are cleaned and re-lubed with slide rail grease. Also, sometimes when pushing the piston back into the caliper to make room for new pads it gets pushed in crooked. Then, when pressure is applied (ie, brake pedal) the piston binds. Make sure everything is cleaned, lubed, and properly assembled and you shouldn't have any problems.
  #3 (permalink)
Old 06-03-2007, 06:11 PM
marragtop is starting off with a positive reputation.
Make sure you are bleeding at the bleeder screw and not the hose connection. Also, always start the brake furtherst from the master cylinder. RR, LR, RF, LF.
__________________
'88 F150 4x4
'91 Explorer XLT 4x4
'92 Explorer XLT 4x4
'95 Explorer XLT 4x4
If it don't = 16 (4x4), it ain't worth driving...
  #4 (permalink)
Old 06-03-2007, 06:45 PM
MazdaRangerGuy is starting off with a positive reputation.
jonm61... why did you replace the front calipers and hoses? What symptoms were you experiencing that pointed you towards replacing these parts?
The reason I ask is that your low pedal might be due to pre-existing problems that may not necessarily have been repaired with the replacement of the calipers and hoses.
In the mean time, check to make sure you used the brass washers at the hose connections at the calipers and that you did in fact properly bleed them. Really the biggest thing to remember while bleeding is to not let up on the brake pedal while any bleeder is open. Typically its "open bleeder, press brake pedal down, hold pedal down while closing bleeder, let up on brake pedal, repeat until no more air comes out."
  #5 (permalink)
Old 06-05-2007, 11:37 PM
Thanks for the help guys!
You won't believe what the problem turned out to be! The first clue I'll give you--never let a drunk mechanic work on your truck!
This guy's a certified mechanic and family friend, gets drunk while working on my brakes and puts the calipers on the WRONG SIDES and therefore UPSIDE DOWN!
He also, when reinstalling the left front hub, left the old wheel bearing seal on the axle when he put the repacked bearings, along with new seals, back on. I haven't had it diagnosed yet, but my ABS light has been on since he worked on it--suspect he damaged a sensor.
So, Firestone charged me $450 to tear it all back down, repack the wheel bearings and put it back together correctly, including flushing the brakes. Now I've got to pay my local dealer $97.53 to diagnose the ABS light, but they will be gracious and not charge me the diagnostic fee if I let them fix it.
Oh, and I asked the dealer to look at something else when they look at the ABS light...oh yeah, that'll be another $97.53! That's their diag charge--PER COMPLAINT!
I should have just done it myself, but I was visiting my dad and didn't want to risk damaging my nearly new hub--the LF caliper went bad and was almost out of pad.
Oh well, lesson learned....
__________________
Jon
'99 Explorer 4Dr
Go Gators!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
