1993 Coolant Temp Sensor - Ford Truck Enthusiasts Forums
Old 06-02-2007, 08:22 PM
ShannonM2 ShannonM2 is offline
ShannonM2 is starting off with a positive reputation.
I have a 1993 F-150 Ext. Cab, 4wd, 351W.
The temp guage shows very cool. It never makes it to the N in "Normal". I had replace the T-Stat, and a temp sensor, but didn't make any difference. The sensor I had replaced is in the center of the intake, on the drivers side of the intake runners. Are there any other temp sensors? And also, when I had taken that sensor out, there was no coolant visible, it was an air space, and there was some "blackish gunk" on the tip of the sensor? Any clues or suggestions?
Thanks
Old 06-02-2007, 08:31 PM
351slug 351slug is offline
351slug is gaining momentum as a positive member of FTE.
Have you ran some stop leak in it before? Sounds like your your not getting water flow to sender.
Old 06-03-2007, 04:48 AM
92F150Flare 92F150Flare is offline
92F150Flare is gaining momentum as a positive member of FTE.
I think you changed your ACT sensor.......see if this helps
http://i54.photobucket.com/albums/g9...ACTSensor4.gif
Good Luck
Old 06-03-2007, 08:09 AM
Does anyone know if there is a seperate sensor for the gauge only? I did accidently change the act sensor, but had corrected it. The gauge still reads just at the first line before the N in normal, barely make it into the normal operating range.
Old 06-03-2007, 09:10 AM
alstieg alstieg is offline
alstieg is starting off with a positive reputation.
there is a separate sensor for the guage only. it will have only one wire to push on it. the other ECT will be a 2 wire.
Old 06-03-2007, 09:29 AM
subford's Avatar
subford subford is online now
subford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud ofsubford has much to be proud of
Sounds like you got the right one.
Here is a photo of a 5.0 but yours should be in the same places.
Old 06-03-2007, 09:36 AM
Where would the other sensor be located?
Old 06-03-2007, 09:42 AM
subford's Avatar
Quote:
Look at the photo above, the one you want is the "TEMP SENDER".
Old 06-03-2007, 09:44 AM
my engine is a different design than your picture. I'll get a photo posted in a few mins
Old 06-03-2007, 10:02 AM
subford's Avatar
Here is a link to a diagram of a 1993 5.8 showing the TEMP SENDER for the gauge.
http://i54.photobucket.com/albums/g91/subford/Electrical/EEC%20PCM/TempSender5.gif
EDIT
It is number 49 in this link:
http://i54.photobucket.com/albums/g9...empSender5.gif
Old 06-03-2007, 10:24 AM
Here is a link to a picture of my enging with the ECT and ACT sensors noted.
http://64.40.115.138/file/lu/20/196549/MTk2NTQ5fSt7Mjk0MzE1.jpg?download=1
Old 06-03-2007, 10:30 AM
subford's Avatar
EDITED
That is the same as the photo posted above.
The one you noted as the ACT is the ACT sensor.
The one you noted as ECT is the ECT sensor for the Computer, nothing to do with the gauge.
The TEMP sender is at the "o" in sensor of "ACT Sensor".
Old 06-03-2007, 10:43 AM
subford's Avatar
A link to your photo edited for the Temp Sender.
http://i54.photobucket.com/albums/g9...d/Engine/5.jpg
Old 06-03-2007, 10:53 AM
I found it. Thank you. The problem is taht the post of the sensor was corroded, causing a bad connection. I had cleaned it, and the gauge started reading more normal. If it seems to hang low, I'll just replace it. It was quite bad for the corrosion.
Thanks, everyone!
coolant temp sensor drunkenrich 1987 - 1996 F150 & Larger F-Series Trucks 7 03-25-2010 06:40 PM
99 F250 Super Duty 6.8L V10 Coolant System Problems FireFighter12105 1999 to 2016 Super Duty 5 02-15-2010 07:17 AM
Guage Problem 1993 F-150 1993F150302 1987 - 1996 F150 & Larger F-Series Trucks 7 03-12-2005 12:53 PM
351w Temp Sensor kenmaraz Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 10-27-2004 12:16 PM
Coolant temp Sensor Smokey0210 Ford Inline Six, 200, 250, 4.9L / 300 12 10-13-2003 08:31 AM
Tags
1993, 351w, 50, 93, act, coolant, ect, engine, f150, ford, picture, reading, replacing, sensor, temp, temperature, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
