Gas too use in eddie Bauer
Hi All, When I had my 97 5.4l I had use 93 grade gas or the engine woud rattle. Now I have the 2000 5.4 and the manual says 87grade .Should I use 93 anyway? It does not rattle with 87 like the 97 model did.Any suggestions. and I also noticed the Navigator reqiures 93 as well.
Originally Posted by Deshane
So it's not gonna change gas mileage anyway right? and why did the 97 rattle with 87 and not 93?
Not sure about the 97. There can be a number of things that could cause it to pre-ignite with 87.
My personal experience with a 2001 XLT 5.4 is that 89 and 93 octane gas DOES get me increased mileage. It is about a total offset on cost vs savings though.
I mainly use the good stuff when towing, I get a little more range out of a tank that way. from 8 to 11 MPG is the difference I see at 87 vs 92-93 octane. That is almost 90 miles on a tank. Again, do the math, you pay more to get more, so it is totally offset, I just like the better range.
Not to doubt your numbers, but that seems like a huge difference between the two. Most times a vehicle not designed to run the higher octane fuels do not burn them completely resulting in some fuel loss. Now on some of the more modern vehicle computers (Not sure when or if Ford does this) but the computer can sense the fule being used and advance or retard timing to allow the engine to perform its best. Even with some loss, its usually never noticed in the overall MPG.
That's why you're gettign more economy out of the higher octane fuel-the knock sensors aren't seeing any spark knock,so the PCM is actually advancing ignition timing a slight amount,and the enging is running more efficiently. It doesn't have anything to do with a particular fuel octane being beter for fuel mileage-it's just a side effect of the knock sensor's input and the PCM's resulting actions.
JL
Originally Posted by Johnny Langton
Fuel octane has absolutely nothing to do with "gunking up the valves" with carbon deposits.
JL
JL
The following users liked this post:
1998Ranger25L153CID
1983 - 2012 Ranger & B-Series
11-17-2016 10:40 AM
Bronx Jimmy
1997 - 2003 F150
05-02-2011 07:35 PM
