11' or 12 inch clutch in 557ci rebuild
Hello, with my stock 460ci I used a high performance 11'clutch & pressure plate, now that its getting rebuild to a High Performance 557ci with around 600 to 700 horsepower would it pay to go up in size to a good 12'inch clutch ? As my 184 tooth externally balanced flywheel was a 12' from the Ford factory but I had it tapped and drilled to fit a 11' clutch as 12 inch clutch's down here in Australia are very rare, but as I am about to have some parts sent from U-S would it be worth going with the bigger 12''' or just stick with a good 11' inch clutch, Thanks Jamie, Australia...( Gearbox is a 4 speed Toploader )
jamies460
16
08-24-2007 09:44 PM
jamies460
08-15-2007 07:00 AM
jamies460
07-28-2007 06:41 AM
jamies460
12-28-2006 02:17 AM
jamies460
18
11-24-2005 10:32 PM
