'98 Ranger Trouble Codes - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-02-2007, 01:32 AM
Pinhead-227 Pinhead-227 is offline
Pinhead-227 is starting off with a positive reputation.
I scanned my Ranger with my new Scangauge II and came up with 3 trouble codes: P0401, U0100, and P0208.
P0401 - EGR Flow Insufficient
U0100 - Lost Communication with ECM/PCM "A"
P0208 - Injector Circuit Malfunction, Cylinder 8
I've scanned it 3 times now, and P0208 and P0401 always come up. I think this is the first time I've seen the U0100 code. What would be the first thing to look for to fix these trouble codes? What are the most common problems with these Rangers, and what parts should be replaced first?.
I don't have 8 cylinders! Why do I keep getting P0208??
Old 06-02-2007, 07:35 PM
MazdaRangerGuy MazdaRangerGuy is offline
MazdaRangerGuy is starting off with a positive reputation.
P0401 - 95% of the time is a bad DPFE sensor (EGR position sensor). Very quick and easy to replace.. two bolts, a connector, and two small exhaust hoses.
U0100 - I wouldn't worry about this unless it continually comes back.. sometimes the modules have a "brain fart" and lose a packet of data or two, then this code gets stuck in memory for a long long time, only to freak out the first person to scan it.
P0208 - Injector #8? Yes there should be no reason to get this code, obviously. Before jumping to conclusions, run to a local chain parts store as most will scan your codes for free.. keep in mind they'll use a cheap, generic code scanner, but if they come up with something different, there may be a compatibility problem with your Scangauge II. Rare, but it does happen. Also see if there are any software updates available for your Scangauge.
Good luck.
Old 06-03-2007, 01:22 AM
I had a friend scan it for codes tonight (I didn't clear them the other day) and the same ones came up. Including the P0208. He's got one of those fancy, put-your-kid-through-college scan tools.
Old 06-03-2007, 06:35 PM
I would chase the P0401 first... like I said it's likely the DPFE sensor. Replace that and see if it fixes the first code.
I've heard of these things causing some strange symptoms when they go bad... although I don't see any correlation with the P0208... but really that's about the only advice I can give at this moment.
Old 06-03-2007, 10:54 PM
Rockledge's Avatar
Rockledge Rockledge is offline
Rockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to beholdRockledge is a splendid one to behold
FWIW, I've heard of aftermarket chips causing "Lost Communication with ECM/PCM" type codes. Do you have a chip installed? Have you tinkered with the PCM harness connector lately?
You might try erasing the codes and then driving around for a while to see if those funky U0100 and P0208 DTCs come back. I suspect the P0401 will return.
Old 06-04-2007, 05:09 PM
I haven't done anything with the PCM yet. Once I get my engine modifications done I may work on it, but as of right now I haven't even touched it (other than hooking up my Scangauge).
Old 06-04-2007, 08:22 PM
What engine modifications are you performing?
Old 06-04-2007, 08:45 PM
I'm having the head shaved for higher compression (hopefully >10:1), Edging the chamber, and cutting Singh Grooves, PowreLynz, and PowreRingz.
My experience lies with a 2000 2.5L Ranger with an automatic. Singh grooves were added and it was shaved to get compression back to stock. Mileage went up from 23 to 29 mpg and power went up to around 3.0 V6 levels. Here's a pic of that particular head. It doesn't have PowreLynz, PowreRingz, and hasn't been Edged.
http://powrehaus.com/2006/09/21/ford-25-ranger-head-w6-grooves/
Old 06-09-2007, 12:36 PM
I'm updating the original topic to include two more codes that came up when taking a 4 hour trip.
P0500 & P0219
P0401 came up again, and U0100 came up once while on the trip.
Edit: For some reason I can't update the original post so I'll just describe it here.
P0500 - Vehicle Speed Sensor Malfunction
P0219 - Not listed in DTCs.pdf...
Old 06-09-2007, 02:15 PM
According to the 'net, the P0219 is "Engine Over Speed Condition" which means I over-rev'd it down the highway. At what RPM will the ECU trip this code? In other words, what's the redline of my stock '98 Ranger 2.5L 4-cylinder?
96 ranger 2.3l codes p1131 and p0401 danwmarvin Ranger & B-Series 1 09-20-2014 08:55 AM
Code P0100 xaviar 6.0L Power Stroke Diesel 2 08-08-2013 11:23 AM
2006 f150 4.6 misfire / rough idle paultfh 2004 - 2008 F150 3 12-02-2009 04:00 PM
trouble codes p-1378,U0155,u0100 hardint 1999 to 2016 Super Duty 5 05-20-2007 10:51 PM
Trouble code twodivdeep 6.0L Power Stroke Diesel 8 07-16-2006 07:47 AM
Tags
2010, 98, codes, condition, dtc, e250, engine, ford, p0208, p0219, p0500, ranger, reset, speed, trouble
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
