Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 05-31-2007, 12:27 PM
blksiryder's Avatar
blksiryder blksiryder is offline
Garage is empty, add now
blksiryder is gaining momentum as a positive member of FTE.blksiryder is gaining momentum as a positive member of FTE.
JP fuel
well i have been searching around and didn't find much on the use of JP fuels. ie jp4 jp5 jp8. i know that jp4 is bad. but what about jp5 and 8 if i were to add some type of addative to make it less dry? (2 stroke oil 100:1) just wanted to know i have a almost endless stock of jp 8 and 5
  #2 (permalink)
Old 05-31-2007, 02:53 PM
Phydeaux88's Avatar
Phydeaux88 Phydeaux88 is offline
Phydeaux88 is gaining momentum as a positive member of FTE.Phydeaux88 is gaining momentum as a positive member of FTE.
What makes you think JP4 is bad. It is probably the closest to #2.
Try this link and follow other links on the page you will get lots of info.
http://en.wikipedia.org/wiki/Jet_fuel
If you mix it with BD you should have no problems.
Jet fuels are essentially refined kerosene and kerosene is refined diesel.
Some of the newer Jet fuels, like JP5 and JP8 have some additives to affect performance and possibly some lubricity enhancers but shouldnt really prevent it from working in a diesel engine.
The biggest problem in Jet Fuel is the total lack of sulpher lousy lubricity.
__________________
2006 F350 4X4 Crew Cab King Ranch edition strictly factory, for now.
  #3 (permalink)
Old 05-31-2007, 06:45 PM
cookie88's Avatar
cookie88 cookie88 is offline
2001 Ford F-250
cookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant futurecookie88 has a brilliant future
f250juggernaut
JP fuel with two stroke oil or even transmission fluid, which is a high detergent 10wt oil, should run fine. The fuel trucks on base run the same JP-8 going into the birds...so I know it'll burn....just need to lubricate it to keep from scoring your expensive injectors.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
Tags
10wt, jp5, jp8, mix, oil, powerstroke
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
