Distributor won't budge
Hey all,
I've been searching for a while but can't find a problem similar to this. If anyone has run into a similar problem any help would be greatly appreciated.
1990, f250, 460 TFI-IV, E4OD.
Removed the spout and checked the timing and it's at 2 deg BTDC. I loosened the hold down bolt on the distributor to bring it up to 10 deg BTDC and the distributor won't budge. Sprayed it with penetrating oil around the base and let it set overnight - still won't budge. Tapped it with a rubber mallet and sprayed it again and let it set overnight. still won't budge. Is there a secret hold down bolt somewhere on the pumpkin or something? lol.
Thanks for any advice!
You are doing about all you and do, just keep spraying it with PB Blaster.
Before you turn it you might want watch the rotor and move the crank back and forth. It sounds like you have a lot of play or have jumped a tooth.
If you have a lot and you change the timing gears and chain and recheck it your timing might be right on.
I've never had this problem but sure enough read about it several times. :/
So what's causing it to stick?
Aluminum corrosion?
Aluminum. copper, zinc and lead all expand farther than iron when heated and contract father when cooled. :)
If it is the aluminum causing it to stick I'd figure out a way to cool it like dry ice or something and at least try that before putting too much strain on it. If you break it off, it'll still be stuck in there. :/
When I was a kid my friend's dad got a 300 Winchester brass stuck in his brand new resizing die. Threaded it for 1/4-20 and pulled those threads out and the new 5/16"-18 threads too! He was told to try dry ice. He placed the brass down on the block of dry ice, asked "how long you think it'll take?" went to move it to a new place and it startled all three of us when the empty brass case fell out on the floor. :)
Just that fast. :)
Alvin in AZ
Aluminum corrosion?
Just that fast. :)
Alvin in AZ
Originally Posted by bustedflush
Decided not to wait. Worked like a charm. You're a genius!
While checking this thread noticed your handle... and thought wouldn't that be a (b word) if your distributor ended up like that? :/
BTW, thanks for trying the idea out for us! :)
Alvin in AZ
thegreatgate
1997 - 2003 F150
09-04-2018 11:05 AM
BTFordGuy302
23
06-02-2016 05:16 AM
F150Traveller
12-30-2014 05:48 PM
geoffunkel
16
08-24-2012 09:12 PM
78Bill
09-08-2002 03:03 AM
