You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
So, did not see this topic anywhere, my 1977 F-250 400 CI was done by a fellow that used to do propane conversions, it is a dual fuel system.
No brain box or what have you, so he apparently set it up I think to run best on propane, as it is great on propane and will break the wheels loose easier than on gas, gasoline is not as smooth running.
So I imagine it is set up as a compormise system, anyway I have had it where going up hills it has done what I call backfiring, so I was told to take the rotor under the distributor cap and cut one side off, as it is what I call a hammerhead shape and that would stop it, as I guess the thought is that the spark is jumping quicker or something, so I think they said to do it on the following edge.
Anybody ever heard of this?
I'm not sure I understand. Is the assertation here that making the rotor lighter will make it spin faster? I don't think that's going to happen since the rotor is driven off the cam.
If you want your spark happening earlier maybe you should advance the timing a little bit.
__________________
Scott
His: 01 F-250 Lariat, 7.3, ZF-6, NV271. A few mods
Hers: 06 Freestar SEL 4.2l
79 Bronco Ranger XLT.. used be the driver, now waiting to become the project.
96 Grand Marquis LS... 25 mpg commuter
I assume he was saying that it cuts down on the spark jumping too soon, or something like that.
Seems it would focus the spark at the correct point for sparking.
__________________
Scott
Have not tried it yet, thought I would ask here first.
Have only city drove the truck so far now, have not been out on holidays with it yet.
May not get to use it for the usual trips and that is the only time I noticed the problem, due I guess to the heat and the heavy load.
Back fire on LP is usally caused by a lean mixture, Look for an air leak cracked hose etc.
You might be able to richen it up under load but I will need to know what kind of system you have.
__________________
Jim England
Do you have Gas? Propane Execeptional Energy
2012 Escape Ltd FWD, 2005 Explorer Sport Trac 2WD
2004 Escape Ltd FWD, 1996 F350 7.3L CCLB DRW,3" DP,4" Exhaust, Cat Delete, 6637
2012 V-Cross V27FK Super Lite by Forest River TT
