Go Back   Ford Truck Enthusiasts Forums > Misc. > Alternative Fuels, Hybrids & Mileage
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-30-2007, 10:32 PM
mkmchu's Avatar
mkmchu mkmchu is offline
Garage is empty, add now
mkmchu is starting off with a positive reputation.
92 F150 w/ I6 -- E85 Use/Conversion
OK, I have a 92 F150 with a I6. I've seen some suggestions that I can just use E85. The news guys were on the other night and said don't do it. Some threads suggested swapping the injectors to a slightly larger set. This seems to correspond with a E85 computer control/wire set that keeps the EFI open a little longer.
I could fool around with all this. But, the big question on my mind is:
Will I have to replace all the rubber/plastic in the fuel system?
- Fuel pump
- Fuel tank gasket (rubber)
- Fuel lines (dual tank and the octopus is hard to find)
- Injectors?? (I'm getting vague in my knowledge here)
Will I have increased water corrosion? I saw some mention of that. There there a way to counter act the tendency of alchohol to attrach water?
I saw mention of someone running a mix like E50. At what point does the mix start causing some of the problems listed above?
Did I miss anything?
BTW, I have a 93 Mustange with a 5.0. Will the 5.0 behave the same as the 4.9?
Thanks
Kevin
__________________
1992 F-150 4x4
4.9
3.08
  #2 (permalink)
Old 06-04-2007, 02:21 PM
99F150 99F150 is offline
99F150 is starting off with a positive reputation.
Are all the fuel lines metal? If so a custom burned chip should be all that is needed. I put a Diablo Sport custom two tune chip in my 99 Ranger with the 2.5 from a local guy in SD.
Tags
03, 390, 49, 49l, 92, 93, chip, conversion, e85, efi, f150, fe, ford, put, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
