4.6 Vacuum Question
Check all the usual things. Clean the MAF, change the fuel filter, change the air filter too if it hasn't been done
If you can get your hands on a fuel pressure gauge, check the fuel pressures.
With the key-on, engine-off, pressure should be around 40. With key-on, engine idling, it should be around 28-30.
If you have a long enough hose for it, check what it is when you think it's sluggish. And report back
update.
Changed pcv valve,
sea foamed intake,
sea foamed gas tank,
tested egr valve with vac, worked normally,
sprayed MAF with electrical cleaner,
Fuel filter looks new, so i didn't change it yet.
THinking about popping out my front O2 sensors and seeing if vacuum increases.
I'm a little leary of spraying starting fluid around my engine to spot vacuum leaks. lol
I drove to town today on a fairly flat road. With cruise set at 55, I was between 0-4 vacuum.
Changed pcv valve,
sea foamed intake,
I am running 32" tires. Seems like the tranny has to work really hard to keep this boat moving, almost like it is pulling a heavy trailor.
No OBD2 codes to speak of.
I noticed one of the hoses from the evap service port on the firewall goes behind the engine somewhere. THe other one is just hanging out not attached to anything. It doesn't have any vacuum going thru it.
It looks like it should attach behind the throttlebody but someone unhooked it and put a cap over the outlet.
