Rear Shocks on 2002 F150
How many miles on the KYBs? It's good to get input on all
The different shocks available, sometimes the more expensive
Shocks are not the best. Yet, shock performance is subjective.
I would like to try adjustable shocks on a truck, but discovering that they were bad would not be a good
thing. It is amazing how expensive shocks can be, the last two used Explorers we bought still had the OEM shocks installed.
Yes, they were horse sh$&. Keep in mind that good shocks like the KYB Monomax will cost more upfront but will save you money in the long run by not having to replace them over and over. Buy them, you won't be disappointed!
KYB Monomax: Not worth the price
I have been running the KYB Monomax shocks since last Spring (2012), and I really don't like them. They are only marginally better than the stock units at low to moderate speeds where the truck feels a bit tighter over small road bumps, but about the same as OEM at higher speeds. They are decent on bad fire roads, and jeep trails.
However, they did nothing to improve the ride/handling over road undulations. I get repeated side to side sway in sharp turns on roads with uneven surfaces, and worse, I get front end float on straight roads when I hit undulations, especially when towing (even light and well balanced loads), almost scary at highway speeds. The OEM shocks were about the same at the end of their life.
The upside? I like the red color and how they look under the truck...
Normally, I run Bilsteins or Koni, but I thought I'd try the Monomax shocks and I really wish I didn't.
I have Bilsteins in my Porsche, F350, and had them in my Ranger, and they have matched my expectations in each case.
That's my 2 cents....
On my 98', they made an astonishing difference in ride quality and handling. Everyone who ride in the truck comments on how great it rides. No shock I've ever owned has lasted anywhere near this long. I love them and recommend them to others all the time with great return info.
Blade, but this idea might be too MICKEY MOUSE for some people.
I have resorted to removing 14 year old rusted OEM shocks of an Explorer
With a Tigersaw. The Tigersaw could actually fit into places a grinder could
Not fit.
I have new Bilsteins ready to be installed on my F150, I will let you guys
Know my impressions after a couple of days with the new shocks.
#30
I was going to suggest using a reciprocating saw with a new steel cutting
Not fit.
Not fit.
The KYB's were a great change for my truck. Ride and handling is 100% better than the stock Ranchos.
