Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 05-29-2007, 11:23 PM
RedSkin12B's Avatar
RedSkin12B RedSkin12B is offline
Garage is empty, add now
RedSkin12B is starting off with a positive reputation.
Water Pump on Flat 6
Quick Question:
I know this may sound like a silly question, but lately I'm hear'n a metalic sound from the front of the engine and I'm wondering if the water pump has bit the dust....did have an aftermarket temp. gauge....I put a thermastate (SP) in and it quit working I think... I know the engine is supposed to run alittle hot... just wondering if that's what it might be or is it something more serious.
Brad
  #2 (permalink)
Old 06-08-2007, 10:24 PM
Snowking's Avatar
Snowking Snowking is offline
1950 Mercury M47
Snowking has a very good reputation on FTE.Snowking has a very good reputation on FTE.Snowking has a very good reputation on FTE.
I would agree and say it wouldn't be too serious worst case scenario replace water pump and flush the coolant system.
  #3 (permalink)
Old 06-09-2007, 11:13 AM
RedSkin12B's Avatar
Well I ordered a water pump rebuild Kit and waited for it to come in before tear'n in the the water pump on my flat 6. I took it off and inspected the water pump and it looked Good and when rotated by hand was quite. So I'm think'n its a lifter or valve in the first cylinder now... one of these days I'll figure out how to put a little video up with sound..bet that would help. Thanks for the reply.
Brad
  #4 (permalink)
Old 06-09-2007, 07:16 PM
RedSkin12B's Avatar
Here, I did what I saw done on here before and put a video of the sounds I'm hearing on Youtube--- http://www.youtube.com/watch?v=V7EhXtCG31Q That is the link to it...take a listen and tell me what you guys think. Thanks
Brad
  #5 (permalink)
Old 06-09-2007, 09:23 PM
Snowking's Avatar
1950 Mercury M47
Nice to see a flat 6 runnin even if sickish, first one I've seen believe it or not.
Well sure you're curious to find out what me thinks.
I don't know if you have pointed the problem noise to the front part of the motor but My vote is on your clutch/flywheel assembly.
How you ask, I am going to say something is loose and when the motor is reved from a idle pressure builds and the "knock" stops.
My secound guess would be a lifter assembly but I do not think so the Knock sounds to loud that SERIOUS damage would be occuring to the valvetrain.
My 2 cents anywho
I'm pullin for ya though just glad to not see any valve covers lol
  #6 (permalink)
Old 06-23-2007, 10:27 PM
flat6inline flat6inline is offline
flat6inline is starting off with a positive reputation.
1950 226 Flathead Ford water pump
Hello, everyone.
Can anyone help me in knowing where to find a water pump for the 226 Flathead six motor ?? This is all new to me. I bought a 1950 226 Flathead six motor. and before I mounted it in my RatRod I wanted to know, if this motor would run. I took out the plugs and it turned over easy. I had great compression on the first 4 cylinders from front to back , but the back two cylinders had none. I took off the intake and the exhaust manifolds and then the side cover plates. and found that the back two cylinders had the exhaust valves stuck open. I took the head off. and found the head to have just been worked on , and the cylinders still had the honing marks in them, Everything was perfectly clean. I sprayed brake fluid and penatrating oil on the valve stems and after working the valve train over and over for about 5 minutes the valves were returning back down when they were suppose to. I was told this motor had very little mileage on this motor and It came out of a 50 mercury car. It sat around in a garage for 6 months. When I bought it the oil was still clean in the motor. I really feel this motor was very recently overhauled. It has a very nice Blue color but I am changing that to Red. The water pump as a small hole on the top side that it shows like it was leaking down the block. Its not the bearing slot hole. It looks like a casing flaw. So I need a good rebuilt water pump . If any one has one or knows where I can purchase one. Please write . and Thank you in advance. RatRoDave
  #7 (permalink)
Old 06-25-2007, 12:08 AM
Snowking's Avatar
1950 Mercury M47
FenCo out of winipeg Manitoba sold me one for a 239. I also have a parts catalogue from LMCtruck.com I would imagine could set you up with one. Also BOTP (blue oval truck parts) whom is a sponser of this website I am sure could also set you up with one.
I suggest BOTP because they sell a good product (also maybe this way I won't get in trouble for mentioning the competion)
Sounds good bout the motor, in my 1949 M47 truck the mtor was rebuilt in the Ford accretied plant in Winipeg Manitoba in 1965 then the truck was parked in 1967 (I do know this to be a fact) and somehow 40 years latr the motor was still mainly unseized and recently reved up for the first time by myself.
Once you do get your 226 goin I suggest burning a little 2 stroke oil lubricant in each tank of gas, todays gasoline is dry and your valve train will thank you.
  #8 (permalink)
Old 06-25-2007, 12:09 AM
Snowking's Avatar
1950 Mercury M47
Hey RedSkin12B
just wonderin whats the story on your machine????
  #9 (permalink)
Old 06-27-2007, 01:20 AM
RedSkin12B's Avatar
Well thanks to my Travel agent I haven't had time to look into it...and I really want to have the parts on hand to fix it if it needs fix'n before I tear in to it. But when I get back from my visit to Fort Irwin I'll look into things....
Brad
  #10 (permalink)
Old 06-27-2007, 02:16 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
7HA-8501 is the waterpump used on 226 engines for F Series trucks.
7HA-8591 is the waterpump repair kit for the above pump.
You might try joblotauto.com for the pump or kit.
Another source is Hemmings Motor News = hemmings.com.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #11 (permalink)
Old 06-28-2007, 09:14 PM
Thumbs up return to sender
Thank you so much for taking time to respond to my questions.
I will look at the two sites you mentioned tonight.. Dave.
  #12 (permalink)
Old 07-16-2007, 01:12 AM
51ford fan's Avatar
51ford fan 51ford fan is offline
51ford fan is starting off with a positive reputation.
Kanter Auto Products lists the Water Pump in there catalog also.
www.kanter.com
__________________
Rod 51 F1 Truck
Flathead 6 / 3.23 Rear
S-10 5-Speed
"Keep on Truckin"
  #13 (permalink)
Old 08-04-2007, 07:51 PM
RedSkin12B's Avatar
Well I took it to a couple of wrench turners I work with and seem to think that the main bearings are bad soo I think I'll try and rebuild the lower half. And see if that fixes it.
Brad
  #14 (permalink)
Old 08-04-2007, 08:25 PM
Snowking's Avatar
1950 Mercury M47
Talk about worst case.
Well better to find it now then later.
Good luck and hope you don't decide to do the easy thing and put in a set of valve covers in your truck
  #15 (permalink)
Old 08-05-2007, 06:03 PM
fordguy76's Avatar
fordguy76 fordguy76 is offline
1978 Ford F-150
fordguy76 is starting off with a positive reputation.
I have a 300 6cyl that made a terrible metal sound and looking it was the waterpump pulley it only had three bolts and at idle it sounded something like your engine then at higher revs it balanced out and was quiet, something like what SNOWKING said, might be the ticket.
__________________
seth cooper
78 F-150 4x4
Ranger XLT
4 inch Skyjacker lift
71 429 4bbl
Tags
1950, 226, 50, 7ha8501, buy, cover, cylinder, flat, ford, inline, noise, pump, repair, timing, water
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
