Mustang Tank article update - venting
Old 05-29-2007, 09:34 PM
jniolon's Avatar
jniolon
jniolon is online now
old and in the way
I'm not venting... the tank is
Quinn Bergmann was nice enough to copy me on his pictures of a tank vent he installed in his mustang tank... AND a solution to the filler neck connection between the tank and the deck filler.... he gave me permission to add it to my Mustang Tank article... sooooo
here it is
mustang tank article update
thanks Quinn
later
John
Old 05-29-2007, 10:08 PM
Fomoko1's Avatar
Fomoko1
Fomoko1 is offline
Received 1,340 Likes on 1,102 Posts
Thanks for adding this John, I`m about to put the Mustang tank in my 53.
Old 05-29-2007, 11:55 PM
imlowr2's Avatar
imlowr2
imlowr2 is offline
Great article John. I've been wanting to install the gas tank in the back for quite a while now. I'm trying to figure out a way of installing it without removing the bed wood (with the exception of the filler). Anyone install one without removing everything? Would love to see pics for ideas.
Old 05-30-2007, 12:08 AM
Fomoko1's Avatar
Fomoko1
Fomoko1 is offline
I`m wondering if it is possible to mount the filler just under the bed (similar to having it behind the licence plate if there was one) to save cutting a hole in the floor for the filler? I think by dropping the tank a small amount I maybe able to do this but I haven`t looked into it yet.
Old 05-30-2007, 12:28 AM
keisha9's Avatar
keisha9
keisha9 is offline
45 degree fuel hose . i wish i could find some of that
Old 05-30-2007, 07:00 AM
jniolon's Avatar
jniolon
old and in the way
Keisha,
go to the parts store or service station.... tell them you want to look at radiator hoses... they make all kinds of prebent hoses.... find one that suits your needs...diameter and angle... buy it... cut out what you need... and there you go...Bob's your uncle !!
John
Old 05-30-2007, 07:36 AM
48' fordster's Avatar
48' fordster
48' fordster is offline
That is a great artical John. I just removed my rear crossmember from my 49 f-3 last night and got the tank in yesterday. I can't wait to get that tank in. so thank you and Quinn for the great info!
Old 05-30-2007, 05:25 PM
Fomoko1's Avatar
Fomoko1
Fomoko1 is offline
I`m hoping to have the bends in the metal inlet tube so I can use a fairly straight piece of rubber tubing made for gas line use. Possibly another upper metal tube if needed for to complete the bends.....
At this point it`s only pipe dreams, we`ll see what happens as I get into it.
Old 05-30-2007, 05:58 PM
true's Avatar
true
true is offline
Great write-up.
Old 05-30-2007, 06:10 PM
keisha9's Avatar
keisha9
keisha9 is offline
i figured thata radiator hose would break down to fuel ... ?
Old 05-30-2007, 06:16 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
Neoprene hose ONLY is used for gasoline hoses and vent hoses.
Do NOT use radiator hose!
Old 05-30-2007, 10:54 PM
LM14's Avatar
LM14
LM14 is offline
Vent Tip
We run dirt late models and all our cars fuel cells are equipped with the rollover valves mentioned. They come in several styles. Check out a few race parts suppliers for some options.
We run a short hose from the rollover valve towards the back of the car. The end of the hose gets an inline fuel filter (cheapo plastic case type) on the end of the hose to keep from getting dirt in the fuel cells. Put the filter on with a simple hose clamp and you will probably never have to worry about it again. If you have to change it, they are available at ANY parts store. Put it on so the flow of air going into the tank matches the flow of fuel arrow on the side of the filter.
Also, instead of welding on the tank, you can get rollover valves with a pair of sealing washers and a nut that goes on the inside of the tank (Check Speedway Motors). Drill the right size hole and the whole thing bolts in with no leaks. A lot safer for those that have already had fuel in their tanks.
SPark
superman64011
32
02-13-2022 10:33 PM
jniolon
08-15-2015 10:01 AM
mattb
19
11-03-2014 01:20 PM
dennisb56
25
06-05-2007 02:04 PM
Ole' Green
01-10-2005 12:19 PM
Quick Reply: Mustang Tank article update - venting
