Go Back   Ford Truck Enthusiasts Forums > Diesel > 1999 - 2003 7.3L Power Stroke Diesel
Sign in using an external account
Register Forgot Password?
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
  #1 (permalink)
Old 05-29-2007, 08:40 PM
amiller93's Avatar
amiller93 amiller93 is offline
Garage is empty, add now
amiller93 has a good reputation on FTE.amiller93 has a good reputation on FTE.
Flashing Air Bag Light - Lamp Fault Code 27
Finally sat down and documented the Passendger Air Bag Deactivation Switch repair. Who needs a 60 buck switch from Ford when it can be fixed for a $1.27.
File Type: pdf Passenger Air Bad Deactivation Switch Repair.pdf (109.2 KB, 3022 views)
  #2 (permalink)
Old 05-29-2007, 09:16 PM
Zip's Avatar
Zip Zip is online now
BC Chapter LDR
2003 Ford F-350
My Garage
Zip has a spectacular reputation.Zip has a spectacular reputation.Zip has a spectacular reputation.Zip has a spectacular reputation.Zip has a spectacular reputation.Zip has a spectacular reputation.Zip has a spectacular reputation.Zip has a spectacular reputation.Zip has a spectacular reputation.Zip has a spectacular reputation.Zip has a spectacular reputation.
That's a great fix isnt it. I did mine awhile back.
__________________
Chris,#12 Official Slackmaster #8
BC Chapter Member/Leader
JOIN THE BC CHAPTER HERE
Zip's 75 F150 Project
RIP Jason. Too soon, way too soon
  #3 (permalink)
Old 12-03-2009, 11:30 AM
wendell77 wendell77 is offline
wendell77 is starting off with a positive reputation.
Holy cow this worked great. thanks for saving me alot of money! it is really simple to do also.
  #4 (permalink)
Old 12-03-2009, 11:53 AM
PaysonPSD's Avatar
PaysonPSD PaysonPSD is offline
Support FTE
1999 Ford F-250
PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.PaysonPSD has a spectacular reputation.
Wendell, Welcome to .
Stick around and be better informed.
Click on the links at bottom of my Sig and enjoy.
  #5 (permalink)
Old 08-15-2010, 05:45 PM
tsmall07's Avatar
tsmall07 tsmall07 is offline
tsmall07 is starting off with a positive reputation.
I love this forum. Every time there is a problem with my truck, I find the fix on here and it usually costs less than $20.
Is the idea here to replace the bulb or just to reflow the solder joints? It seems like the bulb should be replaced. If it is to be replaced, can I get a yellow one at radio shack?
__________________
2000 F350 DRW, 6spd for sale
1996 F150 302 LB (sold)
1971 M35A2 Deuce and a Half (sold) .....1985 BMW 535i
1982 Honda CB750 (for sale)......1995 BMW 540/6
  #6 (permalink)
Old 08-16-2010, 05:46 AM
Zip's Avatar
BC Chapter LDR
2003 Ford F-350
My Garage
Yes the idea is to replace the bulb. I used a clear bulb when I did mine.
__________________
  #7 (permalink)
Old 04-20-2011, 07:47 PM
572166 572166 is offline
572166 is starting off with a positive reputation.
air bag lamp flashing
Hi today i replaced my led for the airbag. The local electronics store sold me a led and a diode they said i needed being its a 12 volt system.The light stoped flashing but the led does not light up? Where did u get your led from? The led is in correctly. Thanks if you can help .
  #8 (permalink)
Old 04-20-2011, 09:02 PM
Zip's Avatar
BC Chapter LDR
2003 Ford F-350
My Garage
I used the small bulb from The Source, which used to be Radio Shack. It was number 1121 or 1127 I think
__________________
  #9 (permalink)
Old 04-21-2011, 12:10 AM
twags6's Avatar
twags6 twags6 is offline
PAA Member #7 and FTE
twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.twags6 has a very good reputation on FTE.
You don't need a diode in a DC system, but you do need a resistor to limit the power to the LED. Are you 100% positive that its in the right way?
__________________
Trevor
01 F-350 CC 8ft bed SRW 7.3L a/t. 186k
PAA Member #7
  #10 (permalink)
Old 04-21-2011, 11:55 AM
timmyboy76's Avatar
timmyboy76 timmyboy76 is offline
timmyboy76 has a good reputation on FTE.timmyboy76 has a good reputation on FTE.
timmyboy76 seadooya
I USED A 12V LED FROM THE SHAXK, AND ITS BEEN WORKING PERFECT....sorry about the caps.
__________________
TIM...PAA#113 LOTS OF PREVENTATIVE MAINT. MODS AND DIY MODS....
  #11 (permalink)
Old 04-21-2011, 12:37 PM
twags6's Avatar
Quote:
Thats the best bet there. Its got the resistor built in.
__________________
Trevor
PAA Member #7
  #12 (permalink)
Old 04-23-2011, 09:34 PM
Thanks for all the information. I got my led from radio shack this time and it worked great,red in color now that is all they had in 12 volt.I needed to pull the radio out also to get at the switch.Thanks again. 99 f350 superduty xcab 8ft bed drw 7.3 a/t 4x4 116k
Tags
1999, 27, air, airbag, bag, bags, code, codes, explorer, f150, fault, flashing, ford, light, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2012, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
