Flashing Air Bag Light - Lamp Fault Code 27 - Page 2 - Ford Truck Enthusiasts Forums
1999 - 2003 7.3L Power Stroke Diesel SPONSORED BY:
Old 02-22-2013, 12:04 PM
Slingnsteel Slingnsteel is offline
Slingnsteel is starting off with a positive reputation.
Great post, easy fix. It cost me $2.14 with tax to fix. Mke sure you get a 12v LED. Tools needed, solder iron, solder, solder sucker. I could not find my solder sucker so used a air hose and blew the solder out from underneath the weld.
SM
Old 05-04-2013, 02:23 PM
Henry Statham Henry Statham is offline
Henry Statham is starting off with a positive reputation.
The Fix worked! Thank You!
1999 Ranger - didn't have to pull the radio but it took a bit of doing to get the switch cover off. Radio Shack's LED selection was pretty thin for 12V, finally found a red one. I also figured out a way to make sure I have the LED in correctly. Plug the module back in, and put the LED wires on top of/ in contact with the old ones. Light on for lamp test when you turn on the ignition = correct, otherwise ignition off, reverse, try again.
Enjoying that cold frosty beer now as directed by the procedure...
Old 05-12-2014, 10:45 AM
beachcamperf250 beachcamperf250 is offline
beachcamperf250 is starting off with a positive reputation.
I wanted to add my 2 cents to this great thread that saved me a huge amount of money. On all lights like this the Longer pin is always Positive.
Picture of Red LED from Radio Shack:
Picture of LED installed, notice longer pin on right (+) (cut before final install):
Old 06-08-2014, 10:07 PM
rbbarron's Avatar
rbbarron rbbarron is offline
rbbarron is starting off with a positive reputation.
Great thread, worked great. This sight has been good to me & my new/used truck!
Old 06-24-2014, 09:27 PM
Reichenbach79 Reichenbach79 is offline
Reichenbach79 is starting off with a positive reputation.
Awesome thread.
This is a great thread. I picked up a green led since the interior ligjting is green and a resistor,(Radio shack didn't have a 12 volt green led). Found out I am not the best at soldering on a circuit board, but with a little patience i got it done. Thanks again!
Air Bags... Where did you mount your gauge and switch? Hessmonster 1999 to 2016 Super Duty 1 11-13-2015 04:09 PM
Air bag light 2/7 7700Rob 1997 - 2003 F150 16 02-16-2015 04:07 PM
air bag code 27 rbbarron 1999 to 2016 Super Duty 9 06-12-2014 12:37 PM
Airbag light 27 - But, does not match other results naiku 1997 - 2003 F150 3 03-11-2011 07:34 PM
air bag code 27? markmartin6fan 1997 - 2003 F150 1 03-11-2008 12:40 PM
Tags
1999, 27, air, airbag, bag, bags, code, codes, explorer, f150, fault, flashing, ford, light, ranger
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
