'94 E4OD kickdown switch
Old 05-29-2007, 10:56 AM
cowchasinsix's Avatar
cowchasinsix
cowchasinsix is offline
I need some help w/ a '94 Bronco w 302 and E4OD with only 52,000 miles. Sometimes when cruising @ 45-50 mph the transmission will "search" for a gear and feel like it's in neutral. This only happens when not being driven hard (1200-1500 rpm) and perhaps going up a slight hill and transmission needs to go down a gear. I am wondering about the switch mounted on driver's side fender which has cable attached to throttle. I don't think that it is connected properly. I can't find anything on this site regarding "kickdown" operations for the E4OD (Looking at it makes me believe it is more of a throttle position sensor for the tranny). Also my DIY manual didn't have much to say about E4OD. Anyway if any of this makes sense please help me out. In advance I had transmission serviced out (fluid flush and filter) didn't seem to help. I also know this isn't Bronco forum, just looking to post somewhere where everybody'll see it. Thanks.
Old 05-29-2007, 11:36 AM
pfogle's Avatar
pfogle
pfogle is offline
With and E4OD the kickdown is computer controlled. I'd start by changing the TPS. If that doesn't fix it pull the codes, a solenoid pack code should pop up.
Old 05-29-2007, 04:51 PM
andym's Avatar
andym
andym is offline
Nope, sounds like the MLPS to me.
Old 05-29-2007, 05:08 PM
mhg's Avatar
mhg
mhg is offline
pull the codes first
also www.fordfuelinjection.com
a wealth of info on the e40d
test all parts before replacing
this can be one of dozens of things
Old 05-29-2007, 06:42 PM
jroehl's Avatar
jroehl
jroehl is offline
Cheapest and easiest thing to do first is to check and/or adjust your shift linkage. Next is to check your fluid--it could be burnt or low (just low enough to only be a problem on a hill). Then pull codes, your TPS may be bad, and when it goes, it makes your tranny feel like it's about to grenade itself. The E4OD is electronically controlled, so no, there is no physical kickdown system--it's all through the TPS and other engine parameters.
Jason
Old 06-08-2007, 02:48 PM
cowchasinsix
Fiddled with it some. Then replaced MLPS-- made it all better. Thanks to all for input.
Old 07-19-2007, 06:02 AM
frdracfan's Avatar
frdracfan
frdracfan is offline
Mlps???? What is that?
Old 07-19-2007, 06:44 AM
jroehl's Avatar
jroehl
jroehl is offline
Manual Lever Position Sensor. Tells your truck's computer what position your shift lever is in.
Jason
Old 07-19-2007, 07:17 PM
lostin90s's Avatar
lostin90s
lostin90s is offline
It on the shaft coming out of trans that you shift cable connects to . Remove cable 1 nut ,Unhook harness ,remove 2 bolts and the MLPS will come off. I have replaced on 4 of my trucks that had same symptoms and no codes . still did it. MLPS FIXED . But do pull codes may be something else.
LOST
LARIAT 85
'80-'86 HOWTO's
28
07-07-2022 03:50 PM
BDFD
18
03-26-2021 12:42 PM
BigSexy78
06-13-2017 08:16 PM
playludesc
04-21-2017 02:36 PM
nlareau
10-01-2011 12:45 PM
Quick Reply: '94 E4OD kickdown switch
