'94 E4OD kickdown switch - Ford Truck Enthusiasts Forums
Old 05-29-2007, 11:56 AM
cowchasinsix's Avatar
cowchasinsix cowchasinsix is offline
cowchasinsix is starting off with a positive reputation.
I need some help w/ a '94 Bronco w 302 and E4OD with only 52,000 miles. Sometimes when cruising @ 45-50 mph the transmission will "search" for a gear and feel like it's in neutral. This only happens when not being driven hard (1200-1500 rpm) and perhaps going up a slight hill and transmission needs to go down a gear. I am wondering about the switch mounted on driver's side fender which has cable attached to throttle. I don't think that it is connected properly. I can't find anything on this site regarding "kickdown" operations for the E4OD (Looking at it makes me believe it is more of a throttle position sensor for the tranny). Also my DIY manual didn't have much to say about E4OD. Anyway if any of this makes sense please help me out. In advance I had transmission serviced out (fluid flush and filter) didn't seem to help. I also know this isn't Bronco forum, just looking to post somewhere where everybody'll see it. Thanks.
Old 05-29-2007, 12:36 PM
pfogle's Avatar
pfogle pfogle is offline
pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.pfogle has a good reputation on FTE.
With and E4OD the kickdown is computer controlled. I'd start by changing the TPS. If that doesn't fix it pull the codes, a solenoid pack code should pop up.
Old 05-29-2007, 05:51 PM
andym's Avatar
andym andym is offline
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
Quote:
Nope, sounds like the MLPS to me.
Old 05-29-2007, 06:08 PM
mhg mhg is offline
mhg is starting off with a positive reputation.
pull the codes first
also www.fordfuelinjection.com
a wealth of info on the e40d
test all parts before replacing
this can be one of dozens of things
Old 05-29-2007, 07:42 PM
jroehl jroehl is offline
jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.jroehl has a spectacular reputation.
Cheapest and easiest thing to do first is to check and/or adjust your shift linkage. Next is to check your fluid--it could be burnt or low (just low enough to only be a problem on a hill). Then pull codes, your TPS may be bad, and when it goes, it makes your tranny feel like it's about to grenade itself. The E4OD is electronically controlled, so no, there is no physical kickdown system--it's all through the TPS and other engine parameters.
Jason
Old 06-08-2007, 03:48 PM
Fiddled with it some. Then replaced MLPS-- made it all better. Thanks to all for input.
Old 07-19-2007, 07:02 AM
frdracfan frdracfan is offline
frdracfan is starting off with a positive reputation.
Mlps???? What is that?
Old 07-19-2007, 07:44 AM
Manual Lever Position Sensor. Tells your truck's computer what position your shift lever is in.
Jason
Old 07-19-2007, 08:17 PM
lostin90s lostin90s is offline
lostin90s is starting off with a positive reputation.
It on the shaft coming out of trans that you shift cable connects to . Remove cable 1 nut ,Unhook harness ,remove 2 bolts and the MLPS will come off. I have replaced on 4 of my trucks that had same symptoms and no codes . still did it. MLPS FIXED . But do pull codes may be something else.
LOST
HOW TO: Changing Carburetors and Making it Work with an AOD LARIAT 85 '80-'86 HOWTO's 21 11-26-2016 12:09 PM
65 F100 Transmission Kickdown Help... taylorjgreen 1961 - 1966 F-100 & Larger F-Series Trucks 4 02-23-2012 08:00 PM
E4OD Shifts From 3rd to 4th Too Early? BDFD 1987 - 1996 F150 & Larger F-Series Trucks 5 08-25-2010 05:07 PM
C6 shift point and kick-down adjustment RC Dan Clutch, Transmission, Differential, Axle & Transfer Case 11 01-06-2010 03:55 PM
C6 Kickdown w/ 460 EFI? DosMas Clutch, Transmission, Differential, Axle & Transfer Case 2 11-12-2007 04:15 PM
Tags
1993, 302, 94, controls, e40d, e4od, f150, gear, kickdown, mlps, searching, switch, test, tramission, trans
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
