Trailer Brake
If you have the factory tow package, the wiring is all the same as you use the factory harness and attach about 4 wires.
The only difference becomes the angle of the brake controller. The Prodigy unit that I have allows a greater degree of freedom with regards to the angle of the controller than some other units. No matter what you choose installation should not take more than 30-60 minutes, depending on how quickly you work.
I have the Prodigy in my 04 Expy, jakermc is right it gives a lot of flexablity on mounting angle (I believe up to 75 degrees). I ordered it online from rjays.com, you can order a wire harness that plugs directly into your truck (if you have trailer tow package), for 12 or 15 dollars extra.
