Who can decode my axle tag??
Old 05-28-2007, 07:30 PM
wyazel1's Avatar
wyazel1
wyazel1 is offline
Heres the numbers off my axle tag. Could anyone tell me what they mean and is this axle any good or should I just plan on looking for a Dana 60 right away
WDH BZ 7LE
50 9 390B
Old 05-29-2007, 01:24 PM
andym's Avatar
andym
andym is offline
Looks like a Ford 9" axle with 3.50 gears on an open carrier.
Old 05-29-2007, 04:27 PM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
WDH BZ 7LE
50 9 390B
Are you certain the code is WD H-BZ? There is no listing for this code in any 1957/89 Truck parts catalog, and nothing in any 1957/79 Ford car parts catalog. The WD portion is late 1960's/1970's. The only catalog I don't have is 1973/79 Lincoln-Mercury, so if that wd H is correct, I suspect that what the center section is from.
Old 05-29-2007, 04:57 PM
wyazel1's Avatar
wyazel1
wyazel1 is offline
Thanks for catching that. Upon closer inspection it does look like an 'H' but on the back of it where its stamped thru its clearly an 'M'. So I cleaned the rest of the dirt/grease out and indeed it is 'WDM'. What difference does the M make if any? Thanks!!!!!
Old 05-29-2007, 05:59 PM
mudder460's Avatar
mudder460
mudder460 is offline
Is there a site that can decode these? I want to decode mine but I don't want to bother someone to do it for me.
Old 05-29-2007, 07:24 PM
NumberDummy
The difference is...the rear axle ID tag can now be decoded!
WDM-BZ = Ford 9 Inch / 3.50-1 / Non Locking
FTE has axle decoders for the VIN plate axle codes. I'm not sure if the FTE decoder can decode the rear axle tag, which this WDM-BZ is. but Mil1ion and I (and prolly others here) can decode the rear axle tags. Both of us are using Ford parts catalogs. It's not a bother to decode them for y'all, it takes less than a minute.
On your Warranty (VIN) Plate is the AXLE code. You can post it, or try the FTE decoder.
Old 05-29-2007, 09:35 PM
mudder460's Avatar
mudder460
I am also trying to find out if my truck was an early production 77. I have found out mostly everything except the serial, all I know is it was made in May 1977. Well if it isn't a problem here are my tags...
Door plate:
F14BNY56245
133 T F141 D04 A 16J
06150 1977 23
Front:
3.50 D7TA ANC
610024 1R
Rear:
NDM-AE2 7DB
3.50 9 397A
Thanks for the help!
Andy
Old 06-01-2007, 02:54 PM
Lee250's Avatar
Lee250
Lee250 is offline
can someone decode mine?
V108B
73 10 2 5J09
Old 06-01-2007, 03:25 PM
NumberDummy
V108B
73 10 2 5J09
V108B = Sterling (Ford WDS) 10.25 Ring Gear / 3.73-1 / Non Locking
Old 06-01-2007, 03:57 PM
NumberDummy
Door plate:
F14BNY56245 F14 = F150 4X4 / B = 300 I-6 / N = Norfolk VA Assembly Plant / Y56245 = 1977
133 T F141 D04 A 16J 133" Wheelbase / T = RED / F141 = F150 4X4 / D = RED Interior / 04 = Styleside - Bench Seat / A = 4 Speed NP435 / 16 = 3.50-1 / J = Power Steering
06150 1977 23 6150 GVW / 1977 / 23 = Memphis, TN Ford District Sales Office
Front:
3.50 D7TA ANC DANA 44 / Free Running Hubs / Non Locking
610024 1R 3.50-1 / 3500 lb Axle Capacity
Rear:
WDM NDM-AE2 7DB Ford 9 Inch / 3.50-1 / Non Locking
3.50 9 397A
Andy
1977 production began in July/August 1976, so a May 1977 build date would not be early production.
Old 06-01-2007, 09:33 PM
mudder460's Avatar
mudder460
Thanks for the info NumberDummy!! I was hoping for an early production front axle, I wanted those 1/2" axle tubes. Another question for you is where do I find my serial number for the truck? Is that what the Y56245 number is? Thanks!
Andy
Old 06-01-2007, 09:48 PM
NumberDummy
Andy
The entire VIN (F14BNY56245) is the serial number.
Old 06-01-2007, 09:57 PM
mudder460's Avatar
mudder460
Reason I am trying to figure this out is, I have been looking in my parts catalogs. Some of the parts I was looking at are for certain serial numbers but they don't look like the VIN numbers. I hope you undertand what I am talking about.
Old 06-01-2007, 10:56 PM
NumberDummy
Yes, in the 1973/79 truck parts catalogs..only the last letter/numbers of the VIN are refered to. For example, all high boy production ended at Y20,000. In the earlier 1964/72 catalogs, from 1964/66 there is a 6 digit serial, no letter applies. The letter/number code wasn't used till 1967. Example 1964/66: F10DR123456. R is the assembly plant...San Jose, CA. Only the 123456 is used for parts changes.
Old 06-01-2007, 10:59 PM
mudder460's Avatar
mudder460
Thanks for the info, now I know!!
Quick Reply: Who can decode my axle tag??
