Who can decode my axle tag??
Originally Posted by wyazel1
Heres the numbers off my axle tag. Could anyone tell me what they mean and is this axle any good or should I just plan on looking for a Dana 60 right away
WDH BZ 7LE
50 9 390B
WDH BZ 7LE
50 9 390B
Thanks for catching that. Upon closer inspection it does look like an 'H' but on the back of it where its stamped thru its clearly an 'M'. So I cleaned the rest of the dirt/grease out and indeed it is 'WDM'. What difference does the M make if any? Thanks!!!!!
WDM-BZ = Ford 9 Inch / 3.50-1 / Non Locking
FTE has axle decoders for the VIN plate axle codes. I'm not sure if the FTE decoder can decode the rear axle tag, which this WDM-BZ is. but Mil1ion and I (and prolly others here) can decode the rear axle tags. Both of us are using Ford parts catalogs. It's not a bother to decode them for y'all, it takes less than a minute.
On your Warranty (VIN) Plate is the AXLE code. You can post it, or try the FTE decoder.
I am also trying to find out if my truck was an early production 77. I have found out mostly everything except the serial, all I know is it was made in May 1977. Well if it isn't a problem here are my tags...
Door plate:
F14BNY56245
133 T F141 D04 A 16J
06150 1977 23
Front:
3.50 D7TA ANC
610024 1R
Rear:
NDM-AE2 7DB
3.50 9 397A
Thanks for the help!
Andy
Door plate:
F14BNY56245
06150 1977 23
Front:
3.50 D7TA ANC
610024 1R
Rear:
NDM-AE2 7DB
3.50 9 397A
Andy
Door plate:
F14BNY56245 F14 = F150 4X4 / B = 300 I-6 / N = Norfolk VA Assembly Plant / Y56245 = 1977
133 T F141 D04 A 16J 133" Wheelbase / T = RED / F141 = F150 4X4 / D = RED Interior / 04 = Styleside - Bench Seat / A = 4 Speed NP435 / 16 = 3.50-1 / J = Power Steering
06150 1977 23 6150 GVW / 1977 / 23 = Memphis, TN Ford District Sales Office
Front:
3.50 D7TA ANC DANA 44 / Free Running Hubs / Non Locking
610024 1R 3.50-1 / 3500 lb Axle Capacity
Rear:
WDM NDM-AE2 7DB Ford 9 Inch / 3.50-1 / Non Locking
3.50 9 397A
Andy
Door plate:
Front:
Rear:
3.50 9 397A
Andy
Thanks for the info NumberDummy!! I was hoping for an early production front axle, I wanted those 1/2" axle tubes. Another question for you is where do I find my serial number for the truck? Is that what the Y56245 number is? Thanks!
Andy
Andy
Reason I am trying to figure this out is, I have been looking in my parts catalogs. Some of the parts I was looking at are for certain serial numbers but they don't look like the VIN numbers. I hope you undertand what I am talking about.
