Who can decode my axle tag?? - Page 2 - Ford Truck Enthusiasts Forums
Old 07-08-2007, 04:30 PM
Mizpahtribe Mizpahtribe is offline
Mizpahtribe is starting off with a positive reputation.
I have a 8.8 from a '89 F150, the tag reads, S806D, 08 88 0F28. I can't find any info to decode this tag.
Old 07-08-2007, 07:10 PM
andym's Avatar
andym andym is online now
andym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputationandym has a superb reputation
8.8" axle, 3.08 open carrier.
Old 12-04-2009, 10:26 PM
10.60onolds455 10.60onolds455 is offline
10.60onolds455 is starting off with a positive reputation.
olds 455
Quote:
Originally Posted by andym View Post
Looks like a Ford 9" axle with 3.50 gears on an open carrier.
Its not 3.50 its a 3.25 open carrier
Old 12-08-2009, 04:08 PM
triplecreek's Avatar
triplecreek triplecreek is offline
triplecreek is starting off with a positive reputation.
If its not to much trouble could you help me with my tag.
wdm bv4 88A
2 75 9 3518
Old 12-20-2009, 01:52 PM
markwie markwie is offline
markwie is starting off with a positive reputation.
My first post and a google search led me here. Axle codes have been driving me nuts.
I'm looking for my 99 F350 4x4.
The rear axle metal tag reads: L 73 10 5 8C09
I'm guessing it's Limited Slip 3.73 10.5" and cant even guess the 8c09. There's also a blue paper band on the right tube that says 141B
On the front there's a big paper tag that says F 81A-3002-CJ I didnt see a metal tag but that doesnt mean it isnt there.
What has me really wondering about this is when the truck is placed in 4x4 It seems that the rear end locks up. I get hard tire scrub in a tight turn on the rear end when it's in 4x4 on the inside wheel, even if I do not lock the front hubs. It does not do that unless I pull the lever to put it in 4x4 and frankly it has me scratching my head.
Old 12-21-2009, 08:06 PM
'77fordtony '77fordtony is offline
'77fordtony is starting off with a positive reputation.
hey, i have an front axle that i pulled off a truck i bought for parts not too long ago. its a dana 44 off a 3/4 ton i believe (8 lugs and it had leaf springs).
i found the Bill of Materials number. the number is 610040-4.
I tried to look it up on dana's site but it was not on there. Can anyone tell me exactly what this axle is?
will this tell me what the gearing is? open diff. or limited slip? thanks guys, i appreciate it.
Old 03-14-2010, 11:49 PM
9.ford.5's Avatar
9.ford.5 9.ford.5 is offline
9.ford.5 is gaining momentum as a positive member of FTE.9.ford.5 is gaining momentum as a positive member of FTE.
trying to find new ring and pinion gear set for my dana 44 front end and searching for the parts i have found ring gear tooth counts fron 39-44 and pinion gear counts from 8-9 and spline counts bolt counts that are all over the place...i need to order the right gears so can anyone tell me if im missing something from my tag
3.50 D4TA TB
603472 9
i gather thats a 74-75 axle from a f100 or f 150 with part time 4x4...also 3.50 open carrier...but is there anything else i can get from this that might help get me the correct R&P gears
Old 03-06-2012, 11:06 AM
78bigblue's Avatar
78bigblue 78bigblue is offline
78bigblue is starting off with a positive reputation.
I need held figuring out my axles, the front one all i could find was ZLO on the bottom of it. And the rear still had the tag but is not in very good shape, it might not be correct but this is what i traced off of it on to paper..WDM-BZ 8BD (under that is) 3 50 9 390B. Like i said it is really hard to read because of shape its in.
Old 04-04-2012, 01:00 PM
jeff1956ford jeff1956ford is offline
jeff1956ford is starting off with a positive reputation.
Could you help me with my axle tag?
The top line reads WDM-J second line reads 3.50 7AC 311, would these numbers and letters tell the year and gear ratio? Thanks
Old 04-04-2012, 02:03 PM
85e150six4mtod 85e150six4mtod is online now
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Quote:
Welcome to FTE. Feel free to open a new thread for your questions.
WDM-BZ tell us '73-'78 F100, '75-'79 F150, 3.50 ratio, open diff, 31 spline axles. The second line also tell us 3.50 open diff. (3L50 would be 3.50 limited slip)
Not sure on the front axle. Is it a Dana axle, perhaps a Dana 44? Click on "Identify Diff's"
NationwideParts.com
Old 04-04-2012, 02:07 PM
Quote:
Welcome, ditto on starting a new thread. People here will not yell at you and tell you to use the search function like they do at the Toyota sites...
WDM-J says '63-'72 Ford F100, 3.50 ratio, open diff, 28 spline axles. Again the second line says 3.50 ratio, with no "L" indicating an open diff.
Old 07-07-2012, 07:09 PM
BGDion BGDion is offline
BGDion is starting off with a positive reputation.
Rear Axle
Can anyone tell me where I can find a rear axle which is tagged WDM-H
  #28
Old 07-07-2012, 07:19 PM
Welcome to FTE!
From the same decoder ring, cut and pasted for my convenience:
<TABLE style="BORDER-COLLAPSE: collapse" id=table1 border=1 cellSpacing=0 cellPadding=2 width="98%"><TBODY><TR><TD bgColor=#fae9d1>WDM-H</TD><TD>Ford Pickup '63-'72 F-100</TD><TD align=center>3.25</TD><TD align=center>9 in</TD><TD align=center>NL</TD><TD align=center>28</TD></TR></TBODY></TABLE>
3.25:1 ratio, 9" ring gear, non-limited slip, 28 spline axles is a further decode of the decode.
THE TAG AXLE option pack4tag Conventional (Bumper Pull) Towing; Travel Trailers, Pop-ups & Slide-in Campers 15 07-20-2016 02:00 AM
4:55 Front Axle / 4:56 Rear Axle?? 1964FORDTUF 1961 - 1966 F-100 & Larger F-Series Trucks 7 03-11-2014 11:18 PM
Why cant I match rear differential tag to junkyard parts offerings? Lex2002 1999 - 2003 7.3L Power Stroke Diesel 4 07-14-2013 09:41 PM
Which Axle do I have greenwhite1 1994.5 - 1997 7.3L Power Stroke Diesel 9 12-21-2010 01:20 AM
Gear ratio from diff tag (pic inside) JAY95gt Excursion - King of SUVs 12 03-11-2007 09:51 PM
Tags
16j, 350, 44, 610024, anc, axle, d7ta, dana, decode, ford, front, id, s806d, tag, wdmbz
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
