Mustang Gas Tank Question???
I've read the article several times and agree John does a great job. My problem is I'd like to mount a gas tank in the rear but don't want to remove the freshly varnished wood bed and stainless strips I worked hard on to install. I'm trying to figure out a way of mounting this tank from underneath so it is also easily removed, similar to the newer F150 trucks. I was wondering if the gas tank kits that No Limit sells go in easy without removing everything. They claim they have a 16 gallon that fits right in. Would love to see other versions of gas tank installs.
First of all, Thanks for all the replies and great idea. So far I've added a 1/4" tube vent to the filler neck and just now finished adding a 1/4" vent to the tank. It looks much like John's picture on his Tech article addition from yesterday. Mine is not quite as high tech. I used a elbow and a 1/4" swagelok fitting and ran a copper line out to the wheelwell. I had put in a gallon of gas the other night so I was chickens__t to try to mig it so I used my old favorite JB Weld and I will let it cure for 24. I hope its not slow to fill. I have a friend who had a 73 F100 who says he used to carry a wood block with him, drove up on it to slightly raise the side where the filler was to help the fill. I hope to have my tags by the weekend and make a trip to the gas pump. I'll take some pics of this RubeGoldberg like mod tomorrow.
Congratulations on figuring out your vent method. Sounds like a good plan. JB Weld has saved the day many times. I'm sure it will be fine.
I was a little concerned about filling time when I saw the geometry of the fill tube. Your setup was the first I've seen that used a Mustang tank and a side fill. Pretty ingenious. However, if the fill height of the cap is decent, the only problem will be the restriction you have where the tube turns into the tank. Let us know how it works out.
PS mine is their 21 gal version but requires the rear cross member to be moved back.
Originally Posted by B/B ford
Ed, No Limits install kit include some sheet metal clips that slide over the frame before you mount the tank. They support a threaded nut in place and you lift the tank and install bolts from the bottom through a flange on the side of the tank. easy to do. I,ve had mine in and out twice since I finished the bed.
Gas Tank Install Finished
Finally got my tank installed, and vented. I tried filling it and it seems to be no problem the gas runs right in and the filler seems to be ok. I was able to get the truck started right up and I drove it around the neighborhood illegally. I sure wish my license plate would show up soon.
Thanks for everyones help and answers to my questions. I posted a picture in my gallery showing the vent line.
Kennyhbh
11-30-2016 12:26 PM
'70 ford f250
07-30-2012 11:09 AM
jniolon
05-30-2007 10:54 PM
