Won't start, theft light 16 flash code
Old 05-27-2007, 09:43 PM
bristolstud2002's Avatar
bristolstud2002
bristolstud2002 is offline
Engine spins but wont start, noticed theft light was blinking rapidly then throwing 16 flash code, also the odometer was reading -------, earlier today I was working on the pigtail for trailer lights and found the fuse blown in engine compartment fuse box, never removed any other fuses or relays, hooked my scan tool to see if PCM had any codes and it wouldnt communicate with PCM, switched PCM relay with fuel pump relay but theft light was still the same, checked all fuses for PCM and PATS and all were ok, tried to start with both keys also but that did't work either, any other ideas, I really dont want to have to drag it to the dealer but im running out of ideas, what do you guys think??
Old 05-27-2007, 09:47 PM
SuperSnake's Avatar
SuperSnake
SuperSnake is offline
same thing happened to mine once. I got it to rest the alarm by pressing the unlock button on the key button if that don't work hit the panic button again and see if it resets. I would check your fuses inside your truck too
Old 05-27-2007, 10:36 PM
Bluegrass 7's Avatar
Bluegrass 7
Bluegrass 7 is offline
The only other thing you can try is the dash diagnotic procedure to see what fault codes it gives but you will still need the services of a dealer.
Old 07-12-2007, 10:02 PM
Ranger354's Avatar
Ranger354
Ranger354 is offline
Must be my night. Do a search for my handle and read the whole post. Fixed mine, and the parts were about $16.00. Relays are in the under hood fuse box. hope this helps. I got the answer from someone on the board. HomerWinslow is his handle. Hope this helps.
Check to see if you have a PCM power relay. If you do swap it with another relay in the box of the same type, preferrably to something that isnt used all the time like a wiper relay. Ive seen this pattern on vehicles that lose PCM power relay at startup causing theft lamp to flash and dashes at the odometer.
Old 06-02-2021, 05:20 PM
Petersonjo2299's Avatar
Petersonjo2299
Petersonjo2299 is offline
what became of that
Old 06-03-2021, 06:21 AM
projectSHO89's Avatar
projectSHO89
projectSHO89 is offline
Originally Posted by Petersonjo2299
what became of that
That was 14 years ago and that user hasn't been around in 12 years.
Remmons
37
07-10-2017 07:28 PM
Crd16
1997 - 2003 F150
08-09-2016 03:54 PM
Castleroc
1997 - 2003 F150
04-18-2016 09:36 AM
kylehoff123
10-06-2013 11:19 PM
TeamMudd
02-27-2011 05:26 PM
Quick Reply: Won't start, theft light 16 flash code
